Previous in Forum: Likely Interview Questions on Utilities   Next in Forum: ASME Example Problem Manual
K Corroded in PVELITE
01/04/2014 8:13 PM
I am designing a pressure vessel in PVELITE. But in the analysis sheet I see k-corroded In the formed head thickness calculation. I found PVELITE uses app 1-4 (c) for the formed head calculation. But in ASME I could not find any k-corroded.
Is it possible to change the design to ug-32?
or
Can somebody advice me how k corroded related to ASME ?
Thanks in advance
Libin
Pathfinder Tags: k corroded- pvelite
Re: k corroded in pvelite
01/04/2014 8:31 PM
Maybe.
I think you are in way over your head here.
That means that I think you don't know enough about vessel design or materials of construction.
PV ELITE: Pressure Vessel Analysis Software - ECE Design
You should go back to the basics. You're not ready for design work on dangerous equipment.
Dished ends (UG32)
Engineering ToolBox
Re: K Corroded in PVELITE
01/04/2014 9:55 PM
It sounds as though PVELITE is cleverer than some of its would-be users, but still not clever enough to include a good Help function.
01/06/2014 9:13 AM
If you are using a licensed version, you can ask your question directly to them. It was easier to call them with technical questions until they were acquired. However, I would request help via the HELP menu in the program.
Register to Reply 3 comments
lyn (1); Mechanicalmark (1); Tornado (1)
