Previous in Forum: Camaro Going Crazy   Next in Forum: Feds May Require Cars to Talk to Each Other to Avoid Crashes
11 comments
Replaced My Radiator
01/06/2014 1:20 AM
I REPLACED MY RADIATOR ON MY 1996 AUDI A6 QUATTRO, 2.8 LITER GAS ENGINE, 4 DOOR SEDAN BODY STYLE. AIR CONDITONING WAS WORKING BEFORE I REPLACED THE RADIATOR BUT NOT AT ALL NOW. WHAT DID I DO WRONG? I ASSUMED THAT I HAD NOT RELEASED THE COOLING GAS, I'M SURE IT WAS UNDER PRESSURE BUT I NEVER HEARD IT LEAKING OUT. AGAIN, WHAT COULD I HAVE DONE WRONG?
ANY & ALL HELP IS GREATLY APPRECIATED,
THANK YOU,
TALK7777777
Good Answers: 70
Re: TALK7777777
01/06/2014 3:04 AM
AGAIN, WHAT COULD I HAVE DONE WRONG? What you did wrong? You opened the hood! The Second thing you did wrong, you assumed you knew what you were doing
Re: TALK7777777
01/06/2014 3:05 AM
You worked on your car.
Re: TALK7777777
01/06/2014 3:34 AM
Quit shouting.
Re: TALK7777777
01/06/2014 8:46 AM
another ANON
Re: Replaced My Radiator
01/06/2014 9:47 AM
Hmmm did you notice some of the radiator was dedicated to the AC ?? replacing the radiator ( all of it ) may have indeed drained your AC system. Some radiators are all in one types, I don't know if the Audi is one of those but this seems likely.
This comes under the classification " Of course I can do it - its simp - - OOPS ".
Rule of thumb #1: if it doesn't work after you messed with it, then its something you did, even if the work you did was supposedly unrelated.
01/06/2014 10:10 AM
did you plug the fan back in?
01/07/2014 12:59 AM
You can not open a refrigeration circuit without evacuation and recharge, and possibly filter change.....The system is probably off on the low pressure switch....Why would you change the condenser coil if it wasn't leaking, the answer is it was that's why you changed it....
01/07/2014 8:51 AM
Once again, a question, a bunch of answers, and NO FOLLOW UP from OP.
01/07/2014 8:59 AM
That's normal anon behavior. No respect. No courtesy.
No GOOD reason to let them post, that I can see.
01/10/2014 11:05 AM
If you disturbed this little guy...that may be the problem...
This is the condenser coil for a '96 Audi A6. You will find that it is/was/should be now...attached to the radiator...
Good Luck!
common knowledge...less common than common sense
Good Answers: 123
01/19/2014 12:27 AM
Bob's rule #2: The last one that touched it screwed it up.
Bob
bob c (1); dj95401 (1); Fredski (2); LongintheTooth (2); lyn (2); SolarEagle (1); The.Tinkerer (1); Tornado (1)
