Previous in Forum: Vertical Wind Turbine   Next in Forum: Gasket Leakage From Blind Flange
9 comments
Material Handling System
01/07/2014 3:02 AM
Needs best material handling system for heavy weight equipments from bay to bay.
weight - Between 10 to 25 tons
Note:
We have 4 cranes for 4 bays.
We need system to move materials between bays. Now you can understand.
Re: Material handling system
01/07/2014 3:25 AM
Duplicate thread alert.
01/07/2014 4:20 AM
You finally providing a bit more information. But since you have done this what else can you tell us? The weights you shift around might or might not be too heavy for handling with overhead crane or forklift. But not knowing more than you provided your best bet is to contact forklift and overhead crane providers to sort out the options.
Other than that a heavy rail trolley system might work.
The more information you provide the better the answer.
For all:
Duplicate thread here.
01/07/2014 6:02 AM
Actually we are in the process of rail with trolley concept to transfer material from one area to another area.
01/07/2014 12:51 PM
Well, if it works do that, then.
Good Answers: 26
01/08/2014 8:40 AM
That is what we did to move heavy steel plates and it works on the long term. Safety made me install an alarm system that alerted when the trolly was activated and or moving.
01/08/2014 10:19 PM
Pls update photos of rail trolley system if available
tnx
01/09/2014 8:53 AM
The update is on the suppliers web page. Please google to access.
Good Answers: 266
Re: Material Handling System
01/07/2014 1:12 PM
25 ton forklift
01/08/2014 11:07 AM
- - from bay to bay - -
Register to Reply 9 comments
IdeaSmith (2); LongintheTooth (1); ozzb (1); Propel (2); PWSlack (1); texasron (1); Tornado (1)
