Previous in Forum: Solar Powered AC Motor   Next in Forum: Bus Duct Design
52 comments
Good Answers: 141
How to Clean Oil Circuit in Old Diesel Engine
01/08/2014 7:20 PM
Dear mechanics,
I have an old 4 cylinder diesel in a boat, that doesn't supply enough oil to the upper parts, camshaft, tumblers, valves. When idling, the oil gauge shows 4 bar oil pressure and when I accelerate to 3000 RPM, the meter shows 5,5 bar. When I remove the valve cover, I hardly see any oil in that compartment.
I'd like to clean the oil circuit, because I expect some dirt clogging up the pressure side of the pump. The engine is hardly accessible, even removing the oil pan is not possible without taking the engine out of the boat. Same goes for removing the oil pump.
Can I add diesel or gas to the oil and let the engine spin to clean the circuit?
Has someone experience with this? I do not intend to let the engine run for a long period, especially not till warm up temperature.
Any suggestions? Thank you for your help. D.
Plenty of room here
Re: How to Clean Oil Circuit in Old Diesel Engine
01/08/2014 7:41 PM
I have cleaned out many engines by overfilling their crankcase with diesel fuel and letting them run for a while.
As long as you don't put any load on the engine everything should take it just fine.
If It was me I would watch your top end parts to see when the fluid makes it up there and how fast it flows.
Good Answers: 104
01/08/2014 7:49 PM
Yeah, maybe add some Marvel Mystery Oil or other additive - definitely NOT GASOLINE.
Good Answers: 141
01/08/2014 8:24 PM
G.A. because It fits me. Only diesel? I though using a mix to get a little bit more oil working? Thank You. D.
Plenty of room here
01/08/2014 9:28 PM
Diesel fuel has good lubricating properties and is designed to stand up to the high pressures created by the moving parts inside fuel injection pump systems so when used as an engine cleaner it does just fine.
If you want something with even better lube and solvent ability use bio diesel!
Don't use gasoline to clean out a running engine, It has near zero lubricating ability.
01/08/2014 9:50 PM
"Don't use gasoline"
Ever!
01/08/2014 7:59 PM
I'd pass on every single shade-tree mechanic clown advise and save it correctly while you have a chance
01/10/2014 5:49 AM
That looks possibly like the cast iron crank from BMC Series A or B engine as fitted to Sprites, MGs of various sorts, Minis and many more cars from Great Britain, Japan and India.
The original cranks on the A-Series are frequency unstable at around 6,000 RPM and break EXACTLY where this crank is broken.
As a replacement, I used to be able to buy forged steel cranks that would not break even under far harsher usage - racing for example. It was not even expensive, even for those days. A firm called Osselli I believe would exchange the damaged block/crank for a rebuilt one with a steel crank for about 50 pounds Sterling if I remember correctly, re-bored, new pistons and assembled.....
I found that you could slowly drive home with an A series motor at low revs with such a break, I actually did it once, drove about 10 miles!!!
Took the engine out, looked at it all over, took it apart and could not at first find the reason for the "BIG BANG", till I noticed oil being squeezed out of the crack when moving the crank.....the parts had remained together....one bright spark wanted to weld it back together!!! NO THANKS.
See here:-
http://en.wikipedia.org/wiki/BMC_A-Series_engine
http://en.wikipedia.org/wiki/BMC_B-Series_engine
A GREAT "Blast from the past!"
Was it a BMC engine of some sort?
Update:- I just found them here:-
http://www.oselli.com/about
WOW!! 51 years and still working!!!
01/10/2014 7:43 AM
crank repair..........
Good Answers: 203
01/10/2014 8:01 AM
Fredski-
A muzzle is also appropriate sometimes, depending who it is.
Good Luck, Old Salt
01/10/2014 1:10 PM
On the lips, it makes a good muzzle!!!
Good Answers: 203
01/10/2014 2:30 PM
I prefer the Heavy Duty Wire Basket Dog Muzzles. They are normally used on the breeds that have the disposition to be bark loudly but most often have no bite after they have experienced the muzzle on them. They can bark all they want from then on but it gets them no where. They can usually be seen on Dobermans, German Shepherds, Boxers, Pit Bulls and Rottweiler's and other four legged species. Occasionally they work very effectively on two legged creatures also, allowing them to bark very loudly but having no bite in their bark.
Many people have found them most effective on old dogs but seldom necessary on younger or well behaved ones.
Good Luck, Old Salt
01/10/2014 1:08 PM
LOL!!
Sadly we had no super glue in the 60's.....
Good Answers: 141
01/11/2014 12:50 PM
Hi Andy,
The version I have is the BL 1.8 liter with rockers and pushers. The oil supply for these is through pedestal 4 that has a hole with fixed position. The pusher shaft is hollow and has 4 (+ 1 supply at the bottom) holes in total where the rockers sit, to supply each rocker with oil. All of these are new.
Plenty of room here
01/11/2014 1:36 PM
I do believe that it was with a similar engine, someone on CR4 had a similar problem and it turned out that the rocker pedestal drilling for oil was not mating with the head drilling. No oil was able to pass. The quality was awful......
Never ever take for granted that parts, not even those made by the original manufacture, will fit!!
I do not remember when or which blog, maybe someone else here will....
In that blog, the rockers were new and from India, so you need to make paper patterns and check that the holes mate up.....its not difficult.
Also, the rocker shaft must match holes with the pedestal......check that too....
Also check the gasket for proper orientation and accuracy....if one is used/needed.....
If you remove the rocker gear and the glow plugs in this case, then turn by hand, the engine in the normal direction, you should see oil flow within a few turns out of the head, and plenty of it too!!!
If yu get plenty of oil, its either the pedestal(s) or the shaft....
If not:-
The next place to check is sadly the head gasket itself and how the head to block borings match up, you need to remove the head of curse......check the gasket and make sure its correctly orientated.Some older engines were mirror images and you could ut it on in two different ways, only one "might" match up to the head/block. Modern engines generally do not have this problem.....
Some engines need an "O" ring to be placed IN the gasket, to seal correctly....
01/08/2014 8:06 PM
I've done it, too. Like tcmtech said, let it idle, don't rev it up.
I honestly don't know if it helped that much, but nothing exploded and the motor ran for years afterward with no problems.
Good Answers: 141
01/08/2014 8:26 PM
G.A. I'll keep you all posted.
Plenty of room here
01/08/2014 8:37 PM
Good Answers: 70
01/08/2014 10:32 PM
Don't know who or how you and dvm got marked as OT, but I did what I could to correct it. GA's for both of you.
dj
01/08/2014 11:05 PM
It's the auto-OT generator.
No since of context.
01/09/2014 8:32 AM
theres an auto - OT ?? nasty.
Good Answers: 141
01/08/2014 11:57 PM
Lyn and myself are bad characters but strong voters. When you off-topic (as a verb) yourself you get 5 votes to handle. Nothing beats that.
Plenty of room here
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
01/08/2014 10:55 PM
We use a product called "EnerFlush" from Enertech labs(WWW.enertechlabs.com). It is formulated to do exactly what you are trying to accomplish. I don't know if it is available to the general public(we're a Govt agency) but it works great.
Nothing is fool-proof to a talented fool
Good Answers: 141
01/08/2014 11:54 PM
Thank you. I need off the shelf solutions. (2.5th W country)
Plenty of room here
01/09/2014 10:24 AM
as you know the oil is the "life blood" of your engine, without the right amount of oil your engine will rapidly wear and it's life will shorten or end. adding more oil over the recommended level in your wet case will not increase pressure or flow. adding a solvent or thinning agent will "wash your bearings of lubrication.terrible idea. there is no such thing as "rebuild in a can", regardless of marketing and price. in an emergency situation all those quick fixes might be utilized but I strongly advise against them.
your engine sounds far beyond a maintenance flush. if anything if you have a varnish build-up inside your engine a flush will just loosen it and pollute your system even more. either your pick-up is restricted or one or more of your oil galleries are.you can tell the pump is turning by the changes in oil pressure you noted. you really need to yank this puppy and get a look at its internal plumbing. you still a functional (weak) engine that you can limp along until you pick a place and time to repair it, I suggest you don't gamble that opportunity away on a Mickey Mouse fix that really doesn't work to address the whole problem. good luck
01/09/2014 11:06 PM
Listen to this man.
Your low oil pressure has nothing to do with clogged lines, or a dirty oil gallery. If it was that bad it'd be a paperweight by now.
If I was a betting man, I would say your lower end has pitting and corrosion from letting it sit without running it, and not changing the oil enough. That's why garage queen owners are shocked to find that the lower ends in their hot rods have about 750,000 miles of wear and pitting on them, when the odometer says less than 750 miles.
Oil collects condensation from the air, and when condensation and the oil combine, it creates a highly acidic formula that eats away at metal, which is why oil manufacturers recommend either a certain amount of distance traveled *or* they say to change it after a specific amoutn of TIME.
The best way to boil the water off is to get it hot enough to evaporate, by running the engine. Sometimes idling won't even get it hot enough. Especially if you have an engine cooled by cold sea water and not a radiator. It must be RUN.
Either this, or your oil pump is worn out.
But as someone who has spent many years working on engines of all kinds, I can tell you it's likely your lower end, leaking like a siv, past your main bearings. Likely. Not for sure.
Best thing to do is to pull the motor, drain the oil, put it on an engine stand or just flip it upside down on blocks, pull the oil pan, and run some plastigauge on ALL of the rod and ALL of the main bearings.
My bet is (And I am sorry...) that the wear and damage will be readily apparent. You might not even need the plastiguage. A rebuild is likely inevitable, but don't worry. Doing it yourself is easier than you think. You just gotta take the right steps, and take your time.
Putting any kind of solvent in your crankcase and running your motor is a sure recipe for even lower pressure, as what little wearing surfaces are left holding even that much pressure in, will lose their lubricity and quickly wear away. The only thing that should ever be in your crankcase is a good, high quality synthetic oil (If you replace your seals. If not, go for high mileage semisynthetic IMO) and maybe a good additive. No solvents. Ever.
If you want clean galleys, take the time to strip the motor down, using wire brushes and a good solvent such as Super Clean. Brush all the galleys, including the drilled holes on the crank. (You will have to remove the plugs for the crank. Use a torch to heat them up, and use teflon tape to seal again when you are done.) You can do the same with the rocker shafts, and the rockers. You will remove by far, more debris, goo, and what not than putting oil- dissolving solvents in your crankcase.
I do this with every motor I rebuild, or care about. It always pays off.
While the oil pan is off, inspect the oil pump. You will immediately notice any galling, scratching, or pitting on the star shaped rotors. If the oil pump is in good shape, but the main and rod bearings are not, then you know what the issue is. If both are looking worn, then that's an issue, too.
I have an anecdotal story to share with you. I bought a 79 Chevy LUV truck, 4x4 some years back. It had an old mechanical oil pressure gauge installed. The gauge would read, about 35-40 PSI when cold, and as it warmed it, it'd drop to about zero. It might hit 3-4 PSI if I revved it high enough.
As I drove it, I could feel the motor, kind of... Slow down for a fraction of a second, then recover. I wasn't sure what to make of it, as the oil pressure gauge was sure to be wrong. No engine could live on 0 PSI. So i fooled myself into believing it was the gauge and just kept driving it.
Ironically, many miles, and almost a year later, it blew the headgasket. I pulled the head, and decided to check the lower end as well.
Yep. The lower end was galled, scratched, pitted, and shot out. It really was making fractional PSI. I attribute it's relatively long life to full synthetic motor oil, but the truth was, it needed a complete rebuild.
Do yourself a favor and do it right. Do you want a locked- up motor when you are in the middle of the Atlantic, with no wind for miles? Or, if it's a backup, you just lost your backup. Are you sure about the condition of the other motor?
Check out forums dedicated to that brand motor. There are people who will devote time to making sure you do it right. I wouldn't be where I am at today if I didn't ask questions, and get my hands dirty.
Good Answers: 70
01/10/2014 12:05 AM
If his oil pressure gauge is accurate, then I wouldn't say he's suffering low oil pressure, 4 bar= approx 50 psi at idle and 5.5 bar = approx 80 psi at 3,000 rpm. But, we don't know where his oil pressure tap is located on the engine.
I do agree about not using any solvents in the oil system and especially any gasoline or highly volatile solvents. I've seen my fair share of General Motor oil pans expanded from bad fuel pump diaphragms dumping gas into the oil pans. Kinda of a Whooshing BOOM!
I would almost suspect the oil pressure regulator/by-pass, but all avenues should be explored.
Good Answers: 141
01/10/2014 12:08 AM
Thank you for your contribution. It has a lot of good craftmanship in it.
The pump, however is not worn out and the pressure is on the high side.
It should be 1.5 - 2 bar on idle and mx 3.5 bar at 2500 RPM. It shows more than double on idle, which points to a restriction between the pump and the plumbing.
The engine has been onder (see) water and the oil became first like dough. This I want to get rid of. I did it once with a RV6 and it worked well with 50% oil and (kill me for it) : Gas.
Anyway, I will keep you all posted. Regards. D
Plenty of room here
01/10/2014 12:52 AM
You're welcome :) Hey, how sure are you that there's supposed to be a lot of oil up top? Have you checked with forums for people who own this engine/ boat? That kind of restriction sounds like particulate, not sludge. Could be wrong. Let us know.
Good Answers: 141
01/10/2014 3:28 AM
Normally I expect a small puddle on top of the head (engine is about horizontal) That doesn't happen. There is only a thin film that covers the parts and the same goes for the inside of the valve cover. If you strike over tumblers, there is not enough oil on the finger to feel comfortable when rubbing the thumb with it. The opening from the oil channel to the top shaft is 3 mm and there is hardly oil coming through. I can almost run the engine without cover.
Plenty of room here
01/09/2014 10:28 PM
Those old engines are usually bulletproof but probably never cleaned. Can you put air pressure through the oil line and blow the crud through? Have you checked to see if, even though the oil may read full, if the bottom half in the oil tank is merely dirty sludge that needs cleaning out?
01/09/2014 10:38 PM
1.) 4 bar is a satisfactory pressure.
2.) If the oil is were not getting to the upper parts of the engine you would have suffered serious wear PDQ.
3.) If you are using the correct oil, the detergent in it will keep the internals including the oil galleries clean.
4.) Don't put gasoline near it.
Good Answers: 39
01/09/2014 11:29 PM
Has no one asked what kind of oil is usually put in this relic? Or the oil change intervals, time or hours run?
Align culture with nature...
Good Answers: 141
01/10/2014 12:31 AM
Shell Rotella 15W40, 2000 Hours or 2 year, what comes first.
Plenty of room here
Good Answers: 203
01/09/2014 11:31 PM
dvmdsc-
As a fellow boat owner I can appreciate the dilemma you are in. When a young lad I had similar problems, the more I fixed the more cropped up. I bit the bullet and yanked the engine and put it on a good stand next to the workbench and fixed the problems. By doing this, while everything on the engine was accessible, allowed me to repair more things better and cheaper, in less time, with fewer bloody knuckles and arms, fewer dunks into the bilge water, fewer words screamed that were not in my mother's or the neighbor's vocabularies and less time spent trying to find tools dropped into the bilge water. You can do a better job by being able to take more of the engine apart with less difficulty and much less time.
You can even set up a rudimentary test stand for the engine and run it as you diagnose the problems.
This also gives you the opportunity to check the frames and planks under the engine mounts after pulling the engine.
Good Luck, Old Salt
Good Answers: 141
01/10/2014 12:24 AM
Thank you old salt.
The problem is that the engine is quite heavy and so is the transmission. All together 730 kg. That would be a job on the land, while the boat is in the water for just 1 year now. These hauling jobs are quite expensive and one never knows how many days work it takes (and waiting time I live with sharks and pirates and boat owners may not work on their boats here- so you give them a blanco check)
Last year I complained about how they fixed the shaft. No problem. But in full ocean the boat took that much water that I had to go full speed ahead to drain it sufficiently.
The boat has a center cockpit and the engine is right under it.
It takes to remove steering stand, floor and everything between.
The boat has 34 years oceans and I honestly don't know if it worth it.
That is why I try a cheap solution. I hardly need that engine, only to make the A/C 's run, to dock, and some canal work where sails are not allowed.
I've crossed the Atlantic a few times and the boat is my "car" to Florida.
All the best.
Plenty of room here
Good Answers: 203
01/10/2014 7:46 AM
dvmdsc-
Fellow sail boater, I didn't realized you were describing a sailboat engine. Being a sail boater myself I can fully appreciate your access problems and desire not to do anything more than what you have to.
I can't contribute anything mechanical that hasn't been said already. The only thoughts I can suggest are: Would a fiber optic inspection camera with the flexible snake connecting the camera to the end of the optics help you see internal parts of the engine that otherwise might be inaccessible? I have used the Rigid 25643 SeeSnake Micro Inspection Camera successfully for inspections not otherwise accessible. DeWalt, Bosch and several others make/sell similar units. I have used it to inspect the internals of centrifugal pumps without disassembly.
Another thing I use is one of those metal mirrors that are included with shaving kits. They are not quite as clear as a glass/silvered one but don't break when dropped. This prevents the wife from screaming when I use her makeup mirror and return it dirty or broken. They can also be "tossed" into a tool box without having to worry about breakage.
May your sails always be filled, not luffing or in irons. Many a safe reaches to you.
Good Luck, Old Salt
01/10/2014 3:04 AM
If possible remove the rocker shaft, use WD 40 to clean the oil channel that feeds the rockers, pipe or oil channel. Run engine to heat the sump oil; add two liter diesel, run with no load at about 1000 r/m max. for 10 min. drain oil. Use 50/50 mix diesel and clean oil; run for 15 min. Drain , replace oil filter and fill with clean propper grade oil.
Rather service at 1 year instead of 2.
Do not run engine only on diesel!
Jurie at seaside at Hermanus [Do not forget the M ] South Africa
01/10/2014 8:05 AM
I'm guessing it has an oil filter. change it. Run B50 Biodiesel for a few tanks. Run a very high detergent crankcase oil all the time, and with a flush package in it, after your voyage for a half hour at idle. (hot engine) Change oil and filter before next voyage. Two or three of these cycles may reduce oil pressure at idle and increase flow to top end. Rotella is great.
Pretty rare to see a problem revealed by high oil pressure at idle, unusual at 2000 hours. We do this occasionally on Sprinter's, approaching 300K miles on several.
01/10/2014 10:35 AM
Change the oil, fresh oil is a great cleaner and a safe bet in your crank case. Run it for a while, let it get good and hot, then change it again. I have done this with truck engines that had a sticky lifter and problem went away for good. On my trucks I would drive it 300-400 miles and change again. Try this twice or three times. You don't need to use the best oil you can find, just SAE or what ever the engine requires. Change out the filter also as it will be catching all that stuff.
01/10/2014 11:09 AM
The best way to clean the engine is change the oil multiple times. A good high detergent oil will clean the engine very well. You might want to put a hotter thermostat in engine to get the oil hotter so it will clean better. The engine may not be running hot enough as it is, which would be causing the sludge issue. The water temperature should be at least 180 F. If you want to spend a little money to clean the oil better, a centrifuge would be a good way to work the solids out of the oil. I wouldn't put ant type of cleaner in the oil. Depending on how heavy the sludge is, it might release too much sludge and clog the pick up screen.
"Never mistake intelligence for wisdom"
Good Answers: 203
01/10/2014 5:38 PM
Catmandu-
GA. Excellent idea, especially on a sailboat where the access is to the motor and components are next to none. Sailboats with inboard auxiliary engines between very small to 60-70 feet have almost no access at all.
We have used the method you describe to clean large gear boxes in industry where we couldn't shut down. Put new oil in it, donnect the pump inlet to the gear box drain, pass it through a "T" with a pressure gauge, old tractor filter housing with an oil filter in it and back in through the oil fill hole. Best to put isolation valves before the pump and after the filter. That way you can change components and filters without shutting the gear box down. No chance of starving the gear box with a clogged filter since it will stop passing oil through the filter and go its normal circulation or splash route.
Good Luck, Old Salt
01/10/2014 1:47 PM
Modern Diesels in Europe are run almost exclusively on full Synthetic oil, it prevents wear far better than normal mineral oil. It also takes all the "crud" and deposits it in the filter......
It is not as cheap as Diesel, but it will protect and clean the engine really well....after you have run on diesel first....
If swarf or similar are causing the problem, almost nothing will move that......
01/10/2014 3:11 PM
FWIW:
Some may consider this to be a jack-leg,shade tree method of doing things, but you cannot argue with results.
If the valves have push rods, remove the rocker arms and the pushrods, and clean the hollow centers of the push rods.These are sometimes clogged with burnt carbonized oil or crud.
After this cleaning, put 1 quart of Dextron ATF in crankcase.Drain out 1 quart of oil first to prevent over filling, which could cause a crankshaft seal failure.
ATF has some very good varnish and laquer solvents that will cut the crud from the passages, but you must have flow through those passages first.Run this through for several hours, as idle,then drain while hot.Change filer.refill with oil and add ATF.Run till hot,Let set overnight.The soaking will help soften the crud.Repeat at least 2 times.Observe results to determine effectiveness.
I have succesfully used this method on old pre-1970 car engines,that were smoking out the blow by pipe,and had same problem with upper engine lubrication.This method resulted in no blow by,and reduced oil consumption.
It worked for me, maybe it will help you.
As stated elsewhere the proper way is to remove the engine and do it right, but desperate times require desperate measures.
Good luck.
Good Answers: 70
01/10/2014 4:22 PM
I've used ATF with a lot of success. When I was with Buick in the '70's we used ATF as top engine flush. Buick V8's were notorious for carbon build up on the back side of the intake valves. The EPA would have been up in arms over it. You'd hold the throttle at about 5k and pour the ATF in the carb. After letting it sit over night, it'd run almost like a fresh valve job. But, man you talk about a smoke screen.
01/10/2014 4:26 PM
endless white clouds
01/10/2014 3:54 PM
Some good replys so far, but I would like to know what type of Diesel engine you have ( manufacturer ) ?also what kind of cooling system ?
A sticky oil pressure relief valve could create higher than normal oil pressure,a wrong oil filter may be another culprit for higher pressure, then the appearent lack of oil on the top end of the engine may be normal on that type of engine. Sorry for so many questions when you are really looking for answers, lastly how much oil is in the engine sump?
01/10/2014 4:05 PM
we rarely get a complete background so guessing and assuming are frequent here!
01/10/2014 4:52 PM
A few details like the OP stated the engine is near horizontally installed has me ruling out a great many Diesel engines that I have first hand knowledge of,then the mention thats "its old" how old? I have been at Diesels since 1965 ish,Come on OP lets have some background.
Good Answers: 141
01/10/2014 8:59 PM
Thornycroft - eqivalent of BMC or BL 109 - 4 cylinder, rotating injection pump, rockers, shaft, pushers, side camshaft, 54 Horsepower, 3500 RPM max, idling 650 RPM,
Gearbox PRM hydraulic. Operating voltage 12 Volts, Original color Blue,
All cast iron, cylinders with dry sleeves, glow plugs, pre-combustion chambers,
Year 1978, Head, valves.springs, gaskets, timing chain, spanners 2013. This motor is still build in India. British Leyland and made history in Morris Oxford, Austin cambridge and also its later 6 cylinder successor. There are about 10.000 of these engines still running every day. Base for some oriental developments.
Thames river boats, Sherpa, Yachts Moody, etc.
Similar to Perkins, but not the same. Pleasant sound. Almost member of the family.
Plenty of room here
01/11/2014 5:08 AM
OK I remember your post on here a while ago RE Rockers on your rebuild.I made a few comments on that thread , Your concerns back then was rockers alliagnment, maybe your present lack of oil in that area is related, AS THE OIL SUPPLY TO THE ROCKERS IS VIA THE ROCKER SUPPORT PEDESTALS,Then again the old rockers that you replaced may have been badly worn and allowing the extra oil to be more visible.In my experience those old " london Taxi " engines were not very oily in the rocker area.
I am now curious to know how you are measuring the oil pressure ?As it happens my brother has one of those engines in his new /old boat he just bought and I have been invited to inspect it, it is in France so it will be a while before I am able to report back.
Good Answers: 122
01/13/2014 8:02 AM
Automatic transmission oil work s well as it is high detergent and has excellent lubrication qualities.
I have used 1 quort for each 5 quarts of engine oil and it has worked well with no engine damage.
I would suspect the high oil pressure bypass valve in the oil pump is clogged and stuck in the open position.
You should see anoticable difference in oil flow within 15-20 minutea and After two good flush sessions with the engine operating at normal temperature for about 30 minutes the difference is amazing.
If you then install 1 quart of ATF to the new oil change wevery time you change the oil for about 100 hours of service the oil system will be very clean.
01/16/2014 7:57 AM
Hi,
I think you should use two wheeler bike engine oil when the bike after come from the garage. I think that will be good.
HSE Engineer LNG
Register to Reply 52 comments
Andy Germany (5); bigg (1); Bugatti (1); Catmandu (1); dj95401 (3); dvmdsc (10); Fredski (5); HiTekRedNek (1); jurie sa (1); LongintheTooth (1); lonster (1); lyn (4); old salt (5); Oraka (1); ormondotvos (1); PFR (1); Satybarole (1); SHOCKHISCAN (1); Solararts (1); tcmtech (2); technicaltom (3); tundrawolf (2)
