Previous in Forum: Variable Square Wave Generator   Next in Forum: Failure of Transformer Incomer Without a Fault Indication
Synchronizing PCC3100 with EGCP 2
01/11/2014 4:07 PM
Good evening,
Is there any possible and safe way to synchronize my power command pcc3100 with my woodward egcp2.I actually have two pcc3100 and need to synchronize to egcp 2
Re: Synchronizing pcc3100 with egcp 2
01/11/2014 5:25 PM
I guess you could make one master and the other 2 slaves, hooked to bus....Set the master manually and have the other 2 auto sync....but I'm just guessing....
01/12/2014 12:25 AM
Hi thank you ,how will they react when the load is going up and down??
01/12/2014 7:13 PM
This should give you an idea of how to hook the control system together...
http://cumminspower.com/www/literature/technicalpapers/PT-9015-P1-Dissimilar-en.pdf
Good Answers: 19
Re: Synchronizing PCC3100 with EGCP 2
01/12/2014 8:51 PM
There are two different controllers. May be you can synchronize with some difficulty but load sharing will not be possible.
Cummins site gives brief about dissimilar sets but not for different make and type of controllers.
Get opinion/advise from both Woodward and Cummins before venturing
Ramesh,Freelance Electrical/automation Consultant
01/12/2014 10:24 PM
We use to synchronize both the WOODWARD EGCP and CUMMINS EFC controllers,both times we use an interface (made by GAC)for it. They are to be used on the load sharing lines, try it because they are simple to used.
01/14/2014 9:25 AM
01/23/2014 1:49 AM
EGCP-2 and PCC 3100 basic functions are same, but the communication between two is a not possible as those are from two different manufactures and address of parameters are predefined by the manufactures.
still you can use for auto sync purpose only. for the load sharing part you can add one load sharing module for each DG set.
Register to Reply 7 comments
Charles Tham (1); kostas voudouris (1); NARASIMHA POWER CONTROLS (1); ramvinod (1); SolarEagle (3)
