Previous in Forum: Failure of Transformer Incomer Without a Fault Indication   Next in Forum: Generator Step Up Transformer Storage Condition
Diagram and Operation of Phase Angle Regulator Which Compensates Reactive Power
01/11/2014 10:31 PM
I have searched for phase angle regulator but it is said that it controls the flow of real power only. i need the operation of PAR(phase angle regulator ) which compensates the reactive power in a power system
Re: Diagram and operation of phase angle regulator which compensates reactive power
01/11/2014 10:44 PM
I'm not sure where you are looking to achieve power factor correction. The closest I'll guess is that you need a brushed synchronous motor used as a synchronous condenser.
01/11/2014 10:52 PM
there are 3 conventional reactive power compensators.
as u told the first one is synch condensor.
the other 2 are saturable reactors and phase angle reactor(PAR).
i need to know the diagram and working of PAR
01/11/2014 10:58 PM
01/11/2014 10:44 PM
You're in luck.
You should search some more. The answer is before you.
Good Answers: 42
01/12/2014 2:40 AM
See:
http://en.wikipedia.org/wiki/Quadrature_booster
Julius
Good Answers: 445
Re: Diagram and Operation of Phase Angle Regulator Which Compensates Reactive Power
01/15/2014 6:52 PM
Karthiga,
I assume that this was an interview question. It is designed to test your knowledge of how power flows in a grid can be controlled, something only an experienced power engineer (or a really, really diligent student) would know.
Think of it this way, there are two components to Apparent Power (S), Real Power (W) and Reactive Power (VAR); therefore, there are only two control actions that can be taken to affect these two quantities. We can change the phase angle between two points which changes the real power flow, or we can change the voltage which changes the reactive power flow, or any combination of both. Two variables, four degrees of freedom, four quadrants of operation.
At a generating station changing the fuel supply affects the phase/torque/power angle, while changing the rotor current affects the voltage level. On the grid the PAR and reactive elements such as LTC (Load Tap Changer), synchronous condensers, capacitors, etc. perform the equivalent functions.
7anoter4,
From your Wiki article: "...A phase angle regulating transformer, phase angle regulator (PAR, American usage), phase-shifting transformer, or quadrature booster (quad booster, British usage), is a specialised form of transformer used to control the flow of real power..."
Real power, not reactive power; there is no such thing as a PAR significantly affecting VAR flow, only reactive elements such as LTC (Load Tap Changer), synchronous condensers, capacitors, etc. do that.
Class dismissed,
Alan
Register to Reply 6 comments
7anoter4 (1); Karthiga Mani (1); lyn (1); RAMConsult (1); redfred (1); SolarEagle (1)
