Previous in Forum: Will This Work, DPDT Switch To Control Power To Unit   Next in Forum: Measuring Resistance
Breaker or Fuse Ratings
01/24/2014 6:10 AM
Guide me on why the standard rating of fuses and breaker are 6,10,16,20,25,32,,63,125 ,100,150,200 etc.Can you provide me the standard in which it has been mentioned the details.
User-tagged by 1 user
Re: breaker or fuse ratings
01/24/2014 6:57 AM
From Wikipedia:
IEC 60269 fuses
The International Electrotechnical Commission publishes standard 60269 for low-voltage power fuses. The standard is in four volumes, which describe general requirements, fuses for industrial and commercial applications, fuses for residential applications, and fuses to protect semiconductor devices. The IEC standard unifies several national standards, thereby improving the interchangeability of fuses in international trade. All fuses of different technologies tested to meet IEC standards will have similar time-current characteristics, which simplifies design and maintenance.
UL 248 fuses (North America)
In the United States and Canada, low-voltage fuses to 1 kV AC rating are made in accordance with Underwriters Laboratories standard UL 248 or the harmonized Canadian Standards Association standard C22.2 No. 248. This standard applies to fuses rated 1 kV or less, AC or DC, and with breaking capacity up to 200 kA. These fuses are intended for installations following Canadian Electrical Code, Part I (CEC), or the National Electrical Code, NFPA 70 (NEC). The standard ampere ratings for fuses (and circuit breakers) in USA/Canada are considered 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600, 700, 800, 1000, 1200, 1600, 2000, 2500, 3000, 4000, 5000, and 6000 amperes. Additional standard ampere ratings for fuses are 1, 3, 6, 10, and 601.
IEC and UL nomenclature varies slightly. IEC standards refer to a "fuse" as the assembly of a fuse link and fuse holder. In North American standards, the fuse is the replaceable portion of the assembly, and a fuse link would be a bare metal element for installation in a fuse.
Good Answers: 266
Re: Breaker or Fuse Ratings
01/24/2014 12:42 PM
Fuse ratings depends on class and type. Which you do not provide. The only fuse I found at 63 amps is a European bottle fuse which fall under DIN standards.
01/25/2014 12:06 AM
It may be related to current ratings of various sizes of cables in metric system like 1.5,2.5,4,6,10,16,25,35mm^2 etc. In imperial system cable(1/044,2/029,3/036,7/029 etc) & fuse ratings(5,10,15,20,30 etc) were different.
pnaban
01/27/2014 5:12 AM
No, it isn't. Cable rating is a function of the installation - just ask BS7671.
India - Member - New Member
Good Answers: 164
01/25/2014 3:55 AM
i recall that these are as per R10 series (Reynolds numbers?). This is mentioned in IEC 60947 i think, can't say for sure.
JohnDG (1); kvsridhar (1); ozzb (1); pnaban (1); PWSlack (1)
