Previous in Forum: Preventing Stainless Steel Contamination In A Raw Store   Next in Forum: Liquified Natural Gas
Used Structural Foam Molds
01/24/2014 11:42 AM
I am looking for used molds to rent or buy to produce Structural Foam pallets or containers.
Thanks, Jim
Pathfinder Tags: Used Molds
Good Answers: 92
Re: Used Structural Foam molds
01/24/2014 12:33 PM
This isn't Kijiji.
Apart from starting with a Google search, you could also provide specifics- such as what continent, country, etc. you are from.
01/24/2014 1:46 PM
Thanks, I am in USA, but the molds can be from anywhere. Did try Google already
01/24/2014 2:49 PM
Try here: Search GlobalSpec
Used Pallet Mold - Alibaba.com
Used Pallet Mold | THINKMOULD China plastic mold manufacturer
www.thomasnet.com › Suppliers
Most molders use these till they have no useful life left.
Good luck.‎
Re: Used Structural Foam Molds
09/23/2014 9:16 AM
I have a client in Florida that is looking to sell a structural foam mold that he is no longer using. This is a very large and heavy industrial mold that was originally purchased for $300,000; however, since he doesn't need it any more, he is very motivated to sell it. Here is a more detailed description of the mold: This is a mold for a structural foam molding press. Structural foam molding is a plastics manufacturing process similar (but not exactly the same) to the better known and more common injection molding process. The bin produced by this mold is typically (but not exclusively) used in agricultural applications. In terms of finished product specifications, the bin produced is approximately 60" L x 40" W x 36" H, and 110 pounds. The mold can produce parts at a manufacturing cycle time of 7 to 8 minutes per bin, depending on the actual press used. The raw material input for use with this mold can be either: (1) the standard recycled HDPE plastic resin; or, (2) a very broad mix of ground or shredded post-consumer plastic waste (plastic soda bottles, plastic milk jugs, etc). The mold was originally manufactured in the early 1990s at a cost of $300,000. It is a very large and heavy mold made of tool grade aluminum and steel. The mold comes equipped with hydraulic pistons that activate to facilitate ejection of the large molded parts. This mold is very flexible; it was designed to be altered through the use of inserts. The flexibility of using inserts to customize the product manufactured is a very valuable feature that significantly increases the orginal cost and resale value of this mold. For pictures, please follow use the Dropbox link below: https://www.dropbox.com/sh/c306y6qqm8wsnmp/AAACDHdUvUTDY2jYYy-AAsHna?dl=0
09/23/2014 11:50 AM
I would like to know more about the price and location and maybe Pix ?
09/23/2014 2:36 PM
Please email me @ simon@2020capitalgroup.com and we can exchange contact info and talk offline.
Register to Reply 6 comments
jimmy302 (2); JNB (1); lyn (1); simonwu2020 (2)
