Previous in Forum: Ceramic Tile   Next in Forum: Google's Future Plans Based On Recent Company Acquisitions
12 comments
Liquid Marble
01/26/2014 8:10 AM
Hi
Do any one have idea as to how to make liquid marble. Please advise me. I remember to have seen a promotional video of product application.
raghu
Good Answers: 141
Re: liquid marble
01/26/2014 8:51 AM
You need to make marble powder and/or granulate and apply it with a binder. The shiny look depends on your mix as well as your used binder. (PU, Epoxy or...) When you decide to bind it with cement, coating and polishing will be needed. Washing the crushed granite will remove dust, that could flatten and discolor your binder. This is for horizontal applications.
Plenty of room here
Re: liquid marble
01/26/2014 9:03 AM
Heat the marble to above the melting point of 825° C.
Good Answers: 141
Re: liquid marble
01/26/2014 9:29 AM
Doing this might cause particles to act as projectiles when a flame is used, depending on the composition. Also the marble doesn't really melt, but decomposes totally and irreversible.
Plenty of room here
Re: liquid marble
01/26/2014 10:23 AM
Have you never heard of flux?
Good Answers: 141
Re: liquid marble
01/26/2014 11:55 AM
I did not apply heat or thermal flux on granite tile. Have only experienced it in firing or electric oven with this result:
>If you fire a granite tile it crumbles after firing as the
>quartz in it goes through a crystal transition at high temperature .
>When it cools it is worthless as a tile. Good glaze ingredient though.(flame)
>If you fire a marble tile it will be converted to quicklime and be lost.
Lyn's marble is different, but there is one character more in his reply - "a". And we two are talking about the same marble, not the glass toy?
I'd like if you share the flux story on marble. I am anxious to learn. Regards. D
Plenty of room here
Re: liquid marble
01/26/2014 3:19 PM
I guess that you haven't heard of flux in smelting. A flux in this application is a lighter non-volatile material that floats on the top of the mineral or rock being smelted. The flux removes impurities and keeps oxygen from the liquefied ore.
Now the OP did not say a thing about getting the liquid to reconstitute as anything that resembles marble. So I informed the OP how hot one must get the rock, marble, to liquefy. The OP just said that a promotional video about product application existed and wanted to know how to make this undefined product. Applying anything as hot as 825° C will be a hazardous operation.
Now cultured marble is a man made composite stone that resembles marble and uses crushed piece of marble in its composition, but it is not marble. I believe that some geologists have fabricated tiny volumes of man made marble just to prove that we understand the metamorphosis that converts limestone to marble.
Good Answers: 141
Re: liquid marble
01/26/2014 6:34 PM
Hi Fred,
This indeed is new ground for me. I checked the link you provided. Thank you so much for sharing. D.
Plenty of room here
Re: liquid marble
01/26/2014 10:40 AM
thats hot!
Re: liquid marble
01/26/2014 9:17 AM
Is this for counter tops?
Re: liquid marble
01/26/2014 10:12 AM
Good Answers: 141
Re: liquid marble
01/26/2014 11:33 AM
If that is what he wants, it is definitely the way to go.
Plenty of room here
Re: Liquid Marble
01/26/2014 12:49 PM
Register to Reply 12 comments
dvmdsc (5); Fredski (1); lyn (1); phoenix911 (1); redfred (3); SolarEagle (1)
