Previous in Forum: Refrigerated Air Dryer 40 cfm   Next in Forum: Dump Trailer Not Lifting
Pressure Vessel Body Flange Design.
01/29/2014 1:05 AM
Dear Friends,
How to design pressure vessel(3800mm Dia. X 7500 L.O.S with 10 kg/cm2-pressure) body flange's OD, PCD, Thickness of flange and No. off Holes of the same as per ASME?
Thanks,
Good Answers: 141
Re: Pressure vessel Body Flange Design.
01/29/2014 2:43 AM
In general ASME is a bit more harsh on material than the European Standards.
However if your autoclave is designed to work in Europe or a metric area, I think you are better of to use the standards of the country of destination.
Besides choice of materials, a 10 kg/cm2 needs to be specified as working pressure or test pressure.
Tests (water tests) comprise also units of expansion and deformation limits.
So first the door, now the flange and tomorrow the vessel? Regards. D
Plenty of room here
01/29/2014 3:08 AM
The trail of threads so far would suggest that the best way to do it is to delegate the task to someone who is more experienced in these matters.
Good Answers: 141
01/29/2014 3:43 AM
This is not a design bureau. More than some ideas we are not allowed to give and yours definitely is good advise.
Plenty of room here
01/29/2014 8:17 AM
The concept of permission does not apply to CR4 users' postings.
The use of an undefined first person plural is abstruse.
Good Answers: 26
Re: Pressure Vessel Body Flange Design.
01/29/2014 12:58 PM
Go to a good college, work in the field for several years, make some mistakes, learn from them, find a good mentor, study the code.
Good Answers: 21
01/30/2014 2:50 AM
You seem to have access to the ASME spec. Thats a very good start!
Why ask a bunch of strangers ? Those persons, who through expert knowledge, drafted the ASME standard, are a much better reference than this forum, and so it should be...
Register to Reply 6 comments
dvmdsc (2); Hilton (1); PWSlack (2); texasron (1)
