Previous in Forum: Insulating Roadways   Next in Forum: I Have No Blinkers
23 comments
Engineering Fields - Electrical Engineering - seek knowledge
Automotive Relay Connection
01/30/2014 9:05 AM
I need to know how to use an automotive 24v relay to connect two negative wire of a device when ignition of the vehicle is switched on.I need the two negative lines to bridge and send information through the. device that the Ignition is on
Re: automotive Relay connection
01/30/2014 9:11 AM
on an automotive system the relays are designed (usually) with the negative as a ground, using the entire car as that ground, so there really is no "switching" of the ground. what is your application? I'm guessing it isn't intended for a vehicle you just want to use some relays from a truck?
01/30/2014 9:15 AM
its a tracking device for trucks I want to use the relay for, it is suppose to bridge the two ground wire while the ignition is on and send information that ignition is on..
01/30/2014 9:48 AM
My suspicious and cynical nature has been stirred. This sounds much like an attempt to defeat the described device rather than install.
What do the printed instructions included with the tracking device have to say about this relay? We haven't heard from them, they probably know what to do.
01/30/2014 12:37 PM
It would be simpler to energise the device's positive wire from a place downstream of the ignition switch, thereby eliminating the need for a relay.
Re: Automotive Relay Connection
01/30/2014 10:14 AM
If you want wiring instructions we have to know what kind of system it is....brand name, model number....If this is something you are designing yourself we need to know what it is designed to do and how it works....If this is just a disabling device or just a timer or a multi-feature gizmo....any relay with a normally open and normally closed set of contacts would be able to perform this function....do you have the schematic for the relay?
01/30/2014 10:22 AM
It is something I ma designing for myself , its is to work as bridge between a ground wire and another wire(white wire).and then the circuit is closed with ignition on.. this is all I need.. this is my concern (the others I can send the information to device)
Good Answers: 117
01/31/2014 10:15 AM
Why design it yourself. Just go into radio shack or any automotive store and purchase a 24 volt relay. The one you want is called a DPDT. Then you can wire in a bomb if like. Alternatively, you can take the voltage off the radio, and ignore the need for a relay.
02/03/2014 2:07 PM
is this a tricky question - i mean - what bloody diference does it make what the polarity of the wires you are bridging is when using a relay - ? bridging a connections ? - u can bridge the batteries in order to have greater load supported[br][br]if you bridge only the negative terminals - you don't have your cirquit closed - only a common ground - or other words you have - - tied (connected) the grids[br][br]
anywone? - is this guy using some other than logic "logic" white wire along whitch the negative wires are bridged - it's you like saying smth. and it actually doesnot say "something" - rather it generates a paradoxial state that opens up a pseudo "logic system" in whih uoy po re eta - confuse your human and get high to cloud share[br][br][br][br][br]? white wire = assigned spirit ? ? bridge 2 [s]similars[/s] same = force pseudo time into the realm of being here ??? 24V / 24h [br][br][br][br] old waters flow weird - muhahaa
ci139
02/03/2014 3:08 PM
actually it's a good one -- how to tell from a single point connection that the circuits have such ???
i guess it's even possible (that'hey've such )
ci139
02/03/2014 3:15 PM
this place CR4 forums is like a surprise egg - you never know which browser is willing to post your typings - besides i don't see the unsubscribe option from this disaster in account management
? why do they hire people for the job these people are not interested of ? perhpas there will be a new v. of browsers this forum thing suddenly will work with ... ? someday - so why to do anything
ci139
01/30/2014 10:24 AM
he wants a proving circuit, anyone capable of wiring in a GPS would find that childs play
01/30/2014 11:40 AM
Agreed, this is the easy part of the described project.
Hmmmmm... let's see... close a switch when the key is turned... what undefined other nefarious purposes could this possibly have?
Good Answers: 266
01/30/2014 12:41 PM
BOOM
Good Answers: 137
01/31/2014 9:36 AM
It doesn't sound like much of a problem.
Connect the relay coil to the ignition circuit (other side to ground of course). Cut the circuit you want to make/break and insert the relay connecting to the contact terminals. It doesn't matter whether the 2ndary circuit is at 0 volt or 24 volt or whatever.
01/30/2014 12:43 PM
There are any number of circuits that are energized when the ignition key is in the "run" position.
I see no need for any relays here, simply tap into an already existing circuit that energizes with the ignition key.
I'm beginning to share Doorman's skepticism on this.
01/30/2014 12:50 PM
Would that be LynDoor microwave-ready instant skepticism, at only $1.99 a pack from all good retail outlets, just add water?
01/30/2014 1:17 PM
Samples also available on-line, free of charge.
Good Answers: 123
01/31/2014 2:26 PM
You are going to have to prove that to me.
Bob
01/31/2014 2:38 PM
Ah... another satisfied customer!
02/03/2014 10:58 PM
Sorry, I've been on a world wide tour of instant gratification delivery technology and have not been able to fulfill skepticism orders as quickly as we'd like.
Don't believe me, well.........................................................
Good Answers: 123
02/04/2014 7:29 AM
I don't believe that either.
Bob
02/12/2014 11:56 AM
You don't believe that either?
It sounds like your order has already been delivered.
02/01/2014 7:05 PM
Dgoldwaters:
It sounds like a simple switch controlled by a voltage; when the ignition energizes the switch closes.
Bulky and expensive relays seem like over kill here.
It sounds like something someone with the most basic of electronics background could solve for a couple of dollars.
This is all I would have to offer until there is a clear understanding of the application.
I would also want to know the voltage between the ground and the other wire, the operating voltage, ampere load, or power consumption of the device being controlled.
Suggestion - send us a picture of the device you are trying to control.
Register to Reply 23 comments
bob c (2); ci139 (3); Codemaster (1); dgoldwaters (2); Doorman (4); Fredski (2); Gavilan (1); lyn (3); ozzb (1); PWSlack (2); SolarEagle (1); Yusef1 (1)
