Previous in Forum: Phase Rotation   Next in Forum: 2001 Chevy Cav
13 comments
How Is Grid Phase Managed?
02/07/2014 9:39 AM
With all the large and small commercial plants as well as the hundreds of thousands of consumer systems now interacting with the grid or local municipality, how does phase of the power, and what would have to be out of phase timing, get handled amongst these systems? Just wondering.
Pathfinder Tags: Phase of the grid
Re: How is grid phase managed?
02/07/2014 10:01 AM
Is this about power factor? If so, then there's yards of information available by entering those words into the Search this Forum box, and clicking on the Go button.
02/07/2014 10:28 AM
A very simplified explanation is that in order to get a return on the power generating investment, the various plants and individuals need to feed power into the grid. This can be accomplished by producing a wave that is at the same frequency, but with a phase slightly advanced, i.e. working to bring the grid wave form to where it needs to be next.
If the produced wave is the same frequency, but does not lead, then power will not flow (assuming the same voltages and waveforms). If the produced wave is the same frequency but lags in phase, power will be coming from the grid, and will be a cost instead of revenue.
Phase mismatch will create large voltage differences and large currents and will trip breakers and/or damage equipment pretty quickly.
The various systems in place to monitor and manage frequency and phase angle don't fit conveniently into an over simplified explanation like this.
Good Answers: 145
Re: How Is Grid Phase Managed?
02/07/2014 12:52 PM
Good question. I have wondered this many times and I don't know the answer. I think that a few months ago there was a show on one of the educational channels that referred to the phasing as being controlled from a "central command center". I suspect that is a true statement but that still does not give the answer.
I suspect that part of the answer might come from understanding that the 60 Hz power frequency is VERY SLOW in comparison to timing that can be obtained from GPS satellites or other sources. Thus, one possible answer would be to issue a directive that a positive zero crossing happened at HH:MM:SS.xxxxx time on xx/xx/xxxx date. From that point forward all zero crossings could be calculated for many years. With accurate clocks you have all the information you need.
There are at least three problems with what I just suggested. First, many years ago I was taught that the power line frequency slowed down and sped up a very small amount based upon load. The power company would balance the speeds out to keep all clocks correct. I don't know for sure that it was true but the sources seemed good.
The second problem with my suggestion is that the phasing would probably need to be adjusted a little based upon what part of the country you are in. Electricity is fast enough that they may not bother with this but every little fraction of a percent of efficiency will start to add up over time.
The third and I'm sure not last problem is that this phase control was done before the GPS satellites were available. Also, it needs to work even if the GPS satellites stop working. Thus, if they use GPS clocks they must also have an alternative method.
In summary, I don't know. Hopefully someone will post the answer.
02/07/2014 1:19 PM
Ummm...crazy-complicated GPS timing aside, since we already do this...and it's not a future thing...
When a grid is initialized the master control station will start up...all follow on stations will sync to that station's output which is...in essense...the phase controller for the grid.
done.
common knowledge...less common than common sense
Good Answers: 145
02/07/2014 4:13 PM
Maybe it is that simple but with all stations (including the master) going up and down at times it seems like something would go wrong. Having each power station drive the line while at the same time being responsible for phasing to the signal that one of the other stations is driving on the line seems awkward.
I assume little home solar cell systems that sell back power will phase to the incoming line. Big plants that can push around the grid seem like a bigger problem. If I personally were to try to have many large scale power plants all driving the same line without better phase control I suspect I would be the lead story on the evening news.
02/07/2014 6:56 PM
"....same time being responsible for phasing to the signal that one of the other stations is driving..."
That seems like the part that makes it confusing. Luckily that it's not happening quitter like that.
There isn't a need for any one entity to oversee and coordinate the phase of all the various sources feeding the grid any more than there is a need for any one entity to oversee the phase angle of all the consumers being fed from the grid.
For the most part, each producer, like each consumer, doesn't engage with multiple other individuals on the grid...it isn't a network in that sense. For the most part, each producer and each consumer engages with the grid at one point. That frequency and phase angle at that connection is what is important....not what the producer down the way is doing.
So, if the grid is up, then the frequency and phase angle at the connection is all you need to be able to contribute. If the grid is down, and you are big enough to get things running, then you just need to target frequency, because there is no one else yet.
While there are certainly dominant players who could induce havoc by introducing arbitrary changes, that would be costly and of no advantage. Moreover, beyond starting up, the timing of the frequency isn't necessarily under the control of an individual producer. It is more of a market equilibrium, but doesn't necessarily look exactly alike at various points on a large grid.
Consider the way that a group of people can begin clapping in unison, or can walk or march in step. It you think about coordinating everyone to achieve the proper timing, it seems dauntingly complicated. But in practice it is very simple, because each individual in the group isn't interacting with every other person but instead is interacting with their local experience of the composite group, or possibly just the individual nearest to them.
02/09/2014 1:50 AM
02/08/2014 12:13 AM
Large inverter-based power generators can locally change the power factor. This was one of the concepts discussed by GE in a seminar I went to concerning large photovoltaic plants. e.g. 10 MW.
Each fuel type has advantages and disadvantages,
02/08/2014 12:53 AM
Of course they can....just like consumers using large inverter power supplies can locally change power factor. That means that the waveform is not necessarily uniform across that grid....which sounds nightmarish, but in actuality, no one has to synchronize with all the various mismatches. Each producer isn't seeing the variations across the gris, they are only seeing the wave form at their own connection.
02/08/2014 1:20 PM
Does that mean that a cumulative error could actually add up to what would be a destructive out of phase condition which actually does not happen due to the stepping of the phase through multiple entities. Or only a number of degrees of error plus or minus?
02/08/2014 9:06 PM
I don't understand what you are asking, perhaps you could rephrase. I offer no guarantee that I will be able to provide a decent answer if you do decide to rephrase your question, but the odds are better than they stand at the moment.
My main contention in that previous comment is simply that everyone interacting with the grid, suppliers and consumers, have an affect on the wave form, but that doesn't create a situation which requires centralized control over all the various connections. I think it is also important to realize that differences in conditions at any moment in time at various locations across the grid, might seem dangerous, but those differences are not seen as any one connection.
02/08/2014 8:44 AM
Here is a very simple explanation. When a generator is connected to the grid, its rotor (which is connected to some engine) is connected to every other generator rotor on the grid through the magnetic field within the generators and the current in the grid. The magnetic fields act as kind of springs which allow each engine to supply power to the grid according to its own capacity. So once the frequency of the grid is determined by the big players, any other generator on the grid is forced to run in lockstep.
02/28/2014 9:25 AM
I just came across this. I thought you might be interested....
http://www.ee.co.za/wp-content/uploads/legacy/02%20TT_Variable_Pg34.pdf
Register to Reply 13 comments
BruceFlorida (2); KeepItSimpleStupid (1); Larry James (1); PWSlack (1); Rixter (2); The.Tinkerer (2); truth is not a compromise (4)
