Previous in Forum: Mars is far away!   Next in Forum: Giant Magnefying Lens in the Sky
Copper Bus Bar Calculation with Derating Factor
02/08/2014 12:15 AM
Hi,
I want copper bus bar calculation of size 2x50x10mm considering the derating factors such as due to temperature rise, due to environmental and enclosure, due to proximity effect. The current carrying capacity of cu bus bar to be considered is 1.5A/Sqmm.
Re: Copper Bus Bar calculation with derating factor
02/08/2014 12:43 AM
Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
This source isn't very good.
How you calculate current carrying capacity of copper bus bar
You should learn to search for the simple stuff. Especially if this is homework.
This one is better.
Electrical Calculations - Download
02/08/2014 2:43 AM
That little chip qualifies as a bus bar?
02/08/2014 5:22 AM
Then look it up in the facility's design protocols.
Good Answers: 117
Re: Copper Bus Bar Calculation with Derating Factor
02/09/2014 9:03 PM
Are you texting from your exam desk?
Register to Reply 4 comments
lyn (1); PWSlack (1); Tornado (1); Yusef1 (1)
