Previous in Forum: About DG Set   Next in Forum: Copper Contained in Transformer
8 comments
About Motor
02/11/2014 10:57 AM
can run a three phase motor in a single phase supply?
Re: about motor
02/11/2014 11:07 AM
Not directly.
Google PHASECONVERTER
Re: about motor
02/11/2014 11:34 AM
Yes you can!
But you need some extra parts and calculations to make it work well.
Here is how it works. 3-phase converter schematic miller system.
Re: about motor
02/11/2014 11:38 AM
Why not just give us all the questions on your test and be done with it?
Re: about motor
02/11/2014 11:45 AM
For the first question of 'Name' put down CR4 Guru's.
Re: about motor
02/11/2014 4:58 PM
one pole
Re: about motor
02/11/2014 5:00 PM
With some additional equipment, yes of course.
Good Answers: 119
Re: about motor
02/11/2014 11:16 PM
Buy a new Variable Frequency Drive (VFD) from a reputable source in your region.
Here is one example from this region.
http://driveswarehouse.com/default.aspx
Or buy a used VFD. I've purchased several used/surplus VFDs (under $30 from ebay) to power 3-phase motors from my home 1-phase power. Very simple to use. You can get full rated torque at any speed up to full motor rating. With adequate cooling, you can get full rated power output up to 150%-200% of rated motor speed.
Disclaimer/Warning: Running over rated speed may be hazardous and may damage the motor.
Re: About Motor
02/13/2014 3:58 PM
Firstly, you have to understand how a single phase motor works. Then ask yourself can you apply this method to a three phase motor
Register to Reply 8 comments
eltech (1); Fredski (1); Kilowatt0 (1); mjb1962853 (1); PWSlack (1); SolarEagle (1); tcmtech (2)
