Previous in Forum: Need Pipe Schedule Calculation formula with available Flow rate.   Next in Forum: Pressure Difference Observed in Pressure Gauge
14 comments
Please Solve My Gear Problem
02/11/2014 10:42 PM
Re: please solve my gear problem
02/11/2014 10:54 PM
I can barely see this.
Isn't inch pounds the force?
Good Answers: 109
02/11/2014 11:04 PM
Where do you apply 3 pounds?
If it rocks back and forth you have a dynamic situation.
6 pounds would be taken where?
I have my glasses on but it does not seem to be a question for rounds.
(with 10 teeth here and there the answer is easy anyway).
Whats the real problem?
02/12/2014 12:46 AM
Poorly stated and illustrated quiz problem. Your answer may be correct for the middle position, but not for the others; and I'm not sure about the middle.
Re: Please Solve My Gear Problem
02/12/2014 8:20 AM
I would have given it a shot.........if I could see the damn thing
02/12/2014 9:41 AM
Sorry did not realize this would be tiny!
should read:
Given:
Sun gear one half inch radius 10 teeth
half blue inner gear 10 teeth
3 inch pounds applied to rock back and forth
solve for force A
My answer is 6 inch pounds?
i don't know if i am right or wrong
tom
02/12/2014 10:23 AM
Your first answer was 6 pounds!
Somebody marked my response OT, not sure why.
02/12/2014 11:32 AM
Because inch-pounds isn't a force.
02/12/2014 11:39 AM
Right. Best to be correct if correcting someone else.
02/12/2014 11:40 AM
i thought 3 inch pounds applied to the half gear was 3 pounds one inch from center
i don't know any other way to say that
thanks tom
02/12/2014 11:58 AM
The word you want is "torque", which you are sometimes confusing with force.
Good Answers: 183
02/13/2014 11:39 AM
I am not sure I understand the problem so that I only try to explain what I understood.The geared sector rolls without sliding on the sun. Its COG is the black point at distance "e" from the sector center and a from the contact point to the sun in the middle position. The weight is considered as applied at the COG. When the sector "rolls" to a 45° position right or left due to the number of teeth ratio the rolling instantaneous center moves with 90° on the sun. The force gives a moment with respect to this center which has to be equal to the moment given by the sector weight in the new COG position. Since the COG is not known in proportion to the radii it is not possible to compute the force. It should be something somewhere which is either no clear in general or not clear to me.
01/11/2016 10:06 AM
Thank you! .... i believe you are correct .... 6 pounds
Impressive answer to a complicated question.
Not easy to view .... extremely difficult to solve.
You may even realize the significance.
Good Answers: 183
01/11/2016 3:32 PM
2 years to see if an answer fits or not this is a real performance!
01/13/2016 10:21 AM
Sad but true, working on this much longer than two years. Maybe you could still help me. Please check your CR4 mail box. thanks tomkoko
Register to Reply 14 comments
Fredski (1); IdeaSmith (1); lyn (3); nick name (2); tomkoko (4); Tornado (3)
