Previous in Forum: Cable Sizing   Next in Forum: Earth Faulth Current Calculation
15 comments
CAT5e (Company A) VS CAT 6 Different Supplier (Company B)
02/19/2014 8:28 AM
CAT 5e company A
IEEE 802.3: 10Base-T; 100Base-T; 1000Base-T;
CAT 6 company A
IEEE 802.3: 10Base-T; 100Base-T; 1000Base-T,1000Base-TX;
But CAT 5e is far more better CAT6 in terms of insertion loss,NEXT,PS NEXT,---
so which cable should i use for backbone for factory.
Re: CAT5e (Company A) VS CAT 6 Different Supplier (Company B)
02/19/2014 9:14 AM
See the Wikipedia article entitled "rational decision-making model".
02/19/2014 9:29 AM
02/19/2014 9:34 AM
Use the yellow one.
02/19/2014 9:47 AM
mazim,
Your title reads:"CAT5e (Company A) VS CAT 6 Different Supplier (Company B)"
The body of your text says,
"CAT 5e company A
IEEE 802.3....................................
CAT 6 company A
IEEE 802.3..................................."
Your lack of consistency indicates that you should do more investigative work. Lots more.
Maybe ask someone knowledgeable in the field? If you get it wrong...........................
02/19/2014 10:02 AM
Quite.
Good Answers: 804
02/19/2014 10:16 AM
You really need to ask this question of your IT department or your Networking people, it makes a difference in the equipment that it can connect to. Many many people ASSume that Cat 6 is "better" than Cat 5e, mostly because the number is higher < insert meme joke here about volume knob going to 11 >.
It's not really true. Cat 6 was created by the Telecom industry because it uses 4 fewer conductors; 2 pairs instead of 4 pairs, that way they can get more bandwidth from smaller cables, or more in the existing cables. The speed is the same however. So to use Cat 6, ALL devices connected to it must support the two bi-directional pair topology, as opposed to the more standard 4 unidirectional pairs in Cat 5e. So Cat 6 is used for more specialized router-to-router links, but if you run it everywhere, you may end up with issues of connecting off-the-shelf devices.
Good Answers: 445
02/19/2014 3:31 PM
JR,
Could you cite some references for this statement, "... because it uses 4 fewer conductors..."?
The only time that's true is if you're referring to 10BaseT or 100BaseT ethernet wiring, where only 4 wires are needed, but not when comparing Cat 5e to Cat 6. 1000BaseT uses all 8 wires for data and signalling and has nothing to do with the type of wire, as long as it's Cat 5e,Cat 6, or higher.
It's a matter of history, when ethernet was first introduced many installations in office buildings, etc. were made over the existing POTS (Plain Old Telephone System) wiring, the ubiquitous R-G-Y-B cable, and the control signals were embedded in the transmit and receive pairs. In order to increase the ethernet speeds to a 1000Mbits/s, it became necessary to have all the transmit and receive pairs' bandwidth dedicated to the data, and 4 more wires became necessary to handle the control signals separately.
Cat 6 wiring is backward compatible with Cat 5e so that either one can handle 1000Mbits/s data and control signals, but physically some Cat 6 cables are bigger because they have thicker individual conductors which may not fit directly into standard plugs, otherwise all equipment is compatible.
The OP should install whatever makes the overseer of the equipment happy.
Alan
Location: Ground Zero of the Pompous and self important....Washington DC
02/20/2014 9:28 AM
Actually the Original 802.3 standard was on Coaxial cable.....that was a few years before it was expannded to work on what we now consider twisted pair lan cable.
It was never designed to work on POTS telephone lines. It was designed to be run on unused frequency bands on a cable tv system as a WAN.
I know this because I was on the developement team that got that particular standard accepted by the IEEE back in the mid 1980's. And there wasn't many of us on that team.
I built the text fixtures...and wrote teh test procedures for testing and aligning the equipment to meet FCC requirements.
Good Answers: 140
02/20/2014 1:29 PM
Ah yes... I remember those days. I never worked with ThickNet (those taps looked dodgy), but did with ThinNet. I so enjoyed changing my home based 8 node BBS setup (using Wilcat BBS software) from ArcNet to ThinNet ethernet. It was a joy! Started off with LANtastic and ended up with Novell Netware. I miss those days.
02/20/2014 2:27 PM
Not me.....I hated working on those with a passion..but nobody I trained ever got close to being as good at it as I was....the best guy took twice as long per unit....all back before there was a single chip solution....I HATED serioal cascade data with digital feedback lopops...and dealing with NRZ data streams. All because CPU's fast enough to process the data at the time didn't exist yet.
Never so happy as I was when I quit that job and moved on to better things.
Good Answers: 140
02/20/2014 2:32 PM
During those days... for me at least, it was a hobby and learning quest. It morphed into a business many years later.
What was it you hated? The ThickNet taps?
02/20/2014 2:56 PM
I was working for the manufacturer (we were paid to design and build them for a major manufacturer who slapped their own labels on them) You can easily guess who we made them for, they had a monopoly for the first few years, if you saw any from the mid to late 80's they had a LOT of components in them...the RF stuff was the easy part....if they weren't working we had to fix them...and working on digital stuff that ran and processed everything WITHOUT a CPU or software...was a nightmare.
NRZ data is non return to zero data....where a zero isn't always a zero and a one isn't always a one....they all depended up previous and successive bits were....then the digital feedback loops cause more headaches than you could imagine....I actually spent the last 26 years trying to forget about it....I wasn't involved in the initial design work on it...just the test beds and procedures. I was however on a redesign to use a higher frequency spectrum.....when the engineer they put on it first screwed up really , really badly. My component choices were utilized on that. That and I built about a quarter of the first few years production myself.
I mostly got out of the manufacturing aspect after that except for a stretch building some early frame relay equipment...and a later stretch on a small team designing a mid range scanning electron microscope.....I was there long enough to get them to the early production stage then left to work as a Satellite network controller. We had a good part of the STS-11 satellite leased on its launch. Got into a lot of work after that for the last 20 years that has me in and out of a lot of government offices and Embassies since then. Off-shoring a lot of manufacturing all but made it impossible to make a really good living in that field in the USA.
02/19/2014 10:20 AM
CAT 6 is better .....
Good Answers: 140
02/19/2014 3:44 PM
Neither... for a factory backbone today, I would use glass, which gets you past the 100 meter length restriction of both cables you mentioned..
02/20/2014 6:21 AM
Fiber is the way to go for long distance runs.
Cat 6 is much more particular in how it is terminated than cat5.The twist must be maintained all the way to the connector.Seasoned cat6 installers always twist the connector before and after conductors are installed into the plugs,before adding boot cover to ensure a minimum untwisted length.Regular cable ties should not be used on cat6;use the Velcro type straps instead.The frequency on cat6 can be so high that the outer insulation of the cable participates in the signal transmission, and must not be deformed or sharply bent.
All things considered,fiber has a greater potential for future expansion,and although it also has a minimum bend radius,(No elbows allowed in conduit, must use pull box or accessible fittings) and requires gentle handling,in the long term it is a better investment for a new installation.
If you are being tasked with this decision,you should do some more research,educate yourself, and make an informed decision for yourself.
Register to Reply 15 comments
HiTekRedNek (1); JRaef (1); lyn (2); North of 60 (3); PWSlack (2); RAMConsult (1); redfred (1); Smoothy (3); SolarEagle (1)
