Previous in Forum: Shallow Head Design.   Next in Forum: Vacuum Breaker for an Open Tank Loop
10 comments
Tie Rod Torque Question (Hydraulic Cylinder)
02/19/2014 1:48 PM
Greetings Everyone,
Are there anyone familiar with calculating the required tightening torque for hydraulic tie rods (as shown in the pic). I am trying to figure out how much torque I should use to tighten the nut. The tie rod are made of mild steel (approximate yield of min 65ksi), the force on the cylinder is around 20,000 lbf and I am using (6) 1/2" dia x 63" Lg tie rods with 1/2-20 threads on each end. I used the machinery handbook as reference using the following formula:
Fi=0.75*At*Sp (At=tensile stress area of bolt, and sp is the proof stress of the tie rod)
I then figured out the torque using T=0.2*Fi*d (Fi from above, 0.2 for mild steel with diameter within 1/4"-1" and d for tie rod diameter.
The only issue I have with the formula is that it does not take the force of the cylinder in account or how long the tie rod is so I don't think that is the correct procedure, can anyone offer some advice, reading material, can PM me directly if you like or post here. Thank you very much.
Re: Tie Rod Torque Question (Hydraulic Cylinder)
02/19/2014 2:31 PM
These don't seem to be the proper type of tie rods for this application....
"Tie-Rods are usually high tensile steel with either cut or rolled threads, prestressed during assembly. Prestressing with proper torque prevents separation of parts when subjected to pressure and reduces the need for locknuts, although locknuts are sometimes used."
http://www.hydraulicguide.com/hydraulic-cylinders-construction/
..."maximum allowable stress is 0.4 x the yield strength"...
http://www.physicsforums.com/showthread.php?t=447419
02/19/2014 2:45 PM
Thanks for the response SolarEagle, the tierod material are either one of the following 1144, 4140 HT or 1045 and heat treated to give sufficient strength. the pre-stressing with proper torque value calculation is what I am after for assembly.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
02/19/2014 10:59 PM
Samantha,
I think you are wanting to look at the elongation of the tie rods but also ensure that they are under the maximum stresses when the cylinder is fully loaded.
Your choice of 6 tie rods is arbitrary until you set the maximum allowable elongation, whereupon you can proceed to look at stresses in the tie rods and zero in on what you require.
The tie rods are there pretty well to keep the cylinder from leaking when pressurized, although there are situations where you will see a bit more load through the rods from how the cylinder is mounted and which end of the cylinder is pressurized.
It might help to visualized them as springs that you will allow to move only say, 0.025" between zero and full pressure. Calculate the pull and therefore stress required on the rod to create this pull and convert it to a bolt torque.
I've noticed that cylinder manufacturers typically limit tie rod cylinders to about 2500 psi, probably because of this issue. I'm guessing that above this pressure it takes too many tie rods to meet the requirements economically and therefore the threaded or welded head design takes over.
Hope this helps,
Jon.
Good Answers: 266
02/20/2014 7:44 AM
The size of the bolts handle the push and pull forces not their torqued down valve. How tight they are torque down only has to insure a good seal on what ever sealing medium is used. Tight enough that there is no movement of the ends. Over torquing can damage this depending on how the seal is installed. Some seals are installed to make contact with inner or outer surface of the tube. Some are installed directly under the edge of the tube. These can be damage if over torqued. Also if torque to tight can distort the tube.
Good Answers: 114
02/20/2014 3:42 PM
The rods need to be fully tensioned to yield to account for the pressure and the rest to keep the seal. The tension should be set with proper equipment, not a torque wrench.
02/20/2014 4:26 PM
Better tell that to the thousands of people who rebuild tie rod cylinders every day...
Jon.
11/24/2014 5:45 AM
Tie rod hydraulic cylinders depend upon the quality of raw material and strokes.
Essem Engineers is one of the leading manufacturer of Hydraulic cylinders and systems.
Good Answers: 117
02/20/2014 11:48 PM
What did the manufacturer recommend?
02/25/2014 11:44 AM
I have found a torque spec from an internet search, below is the link, the tie rod torque is located on the last page (page 6):
http://www.parker.com/literature/Industrial%20Cylinder/cylinder/Serv/1110-M3.pdf
I am very interested in knowing how they came up with those values or what was the procedure used, can anyone offer some suggestions.
07/25/2024 9:51 AM
Call the original equipment manufacturer, and ask.
Register to Reply 10 comments
essemengineers (1); ozzb (1); passingtongreen (1); PWSlack (1); Samantha77 (2); sawmilleng (2); SolarEagle (1); Yusef1 (1)
