Previous in Forum: Stripped Threaded Socket, Can This Be Fixed?   Next in Forum: Mechanical Engineering
10 comments
Backpass
02/26/2014 1:37 AM
I'm new at boiler management, i want to ask what is the meaning of "backpass" in boiler context? (especially in coal-fired steam power plant terms). Where does the term comes from. Regards.
Good Answers: 26
Re: Backpass
02/26/2014 9:15 AM
Are you reffering to "backpass" of a weldment?
Re: Backpass
02/26/2014 10:32 AM
Two sites you need to study, especially the first:
How to Search the Internet - Hannon Library
A Comparison of Online Backpass Cleaning ... - Energy Central
Tips for Posting on CR4:
  • Look for answers before you post. Search CR4 or use a search engine to see if you can find the answer to your question.
Re: Backpass
02/27/2014 4:43 AM
I think Your only assuming that i didn't try to find it in CR4. But there isn't any thread in CR4 that has explained about this. I meant backpass / back pass for boiler in coal-fired steam power plant
Re: Backpass
02/27/2014 10:35 AM
A large utility boiler has a (front pass) furnace, where the tubes "see" the fire with radiative and convective heat transfer. The hot gases travel over the top and down the back pass, where there is primarily convective heat transfer.
Re: Backpass
02/27/2014 3:43 PM
where does this term (backpass) first came from?
Re: Backpass
03/05/2014 9:29 AM
The University of Hardknocks, perhaps?
Re: Backpass
02/27/2014 3:41 PM
Do you have any reference, that states this? (A book/ journal/article)
Good Answers: 181
Re: Backpass
03/01/2014 6:10 AM
I may be wrong, I think you will find it come from either Yorkshire or Lancashire boilers of the 19th century.
One of the two had a back pass (return flue) with a secondary combustion chamber opposite the fire box.
Re: Backpass
03/01/2014 12:36 PM
is there any article or journal which i can refer to that defines what back pass is?
Re: Backpass
03/03/2014 9:51 AM
I thought I had sent this already. Sorry!
A pass is a straight shot of hot gases, horizontal or vertical, past heat transfer equipment. In a large coal- or trash-burning boiler, the furnace (close to the operator, so "front" pass) has upward gas flow, with larger ash particles falling to a collection hopper. Fly ash is entrained with the gas flow up, over, and down the back pass, through an air preheater, turning the corner toward the stack, hopefully past some pollution control equipment. In an old steam locomotive, the boiler has a single, horizontal pass from the firebox to the stack.
http://www.alstom.com%2FGlobal%2FPower%2FResources%2FDocuments%2FBrochures%2Fpulverised-coal-boiler-two-pass-boilers.pdf
http://www.fulton.com/products/productprofile.php?ptc=&uid=7
Anonymous Poster (4); Don in Richmond (2); lyn (1); PWSlack (1); texasron (1); TonyS (1)
