Previous in Forum: Backpass   Next in Forum: Electric Motor for Rotating Cylinder
Mechanical Engineering
02/26/2014 2:21 AM
Hi,I have been asked to design a pulley drive:
Pump and motor size: 3/2CINM with 11kw 4 pole,525V
Motor Shaft dia: 42m
motor speed: 1460
pump shaft dia: 42
req. pump speed: not slower than 1800rpm
centre to centre: 500mm
Required : motor pulley, motor taperlock,pump pulley, pump taperlock,wedge belt size and qty
Please help,I have no clue
Good Answers: 18
Re: Mechanical engineering
02/26/2014 3:33 AM
Hi K9,
Contact your local bearing/drive belt supplier.
The pulley ratio you need is child's play to work out but where you need the expert advice is on the pulley sizes (what is the nearest diameters to give you the ratio you need).
The supplier will also be able to tell you and the number of belts to transmit the horse power.
It might be worth a few "Brownie points" if you also design the guard for the application.
Best of luck,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Re: Mechanical Engineering
02/26/2014 10:53 PM
Refer "machinery handbook" published in USA
pnaban
02/27/2014 3:35 AM
Thank you guys
Register to Reply 3 comments
jesw55 (1); K9 (1); pnaban (1)
