Previous in Forum: Mechanical Engineering   Next in Forum: Calculation of Pressure Versus High Water Column
26 comments
Electric Motor for Rotating Cylinder
02/26/2014 11:00 AM
Hello and thank you if someone can help me. I'm a visual artist with some experience on mechanic and electricity. I would like to make a moving sculpture were a 4 inches diameter cylinder rotate at about 3 seconds each rotations . As you can see in the picture the cylinder (4'' diameter x 8'' long) is connect to a electric motor (the electric motor should be more silence possible, someone suggest me windscreen wiper motor). by a transmission belt (seem to me transmission belt it's better than gears because it should be less noise than gears). The power of the electric motor shouldn't be so much because the 4'' cylinder need just turn but it should turn without stop for hours.
Thank you
Carlo
Re: Electric motor for rotating cilinder
02/26/2014 11:20 AM
Seem to me electric gear motor are too noise
02/26/2014 1:06 PM
Well use something else, then.
02/26/2014 11:22 AM
You might also search on line for 20-rpm shaded-pole gearmotors.
02/26/2014 11:45 AM
I would go with a microwave oven rotational base motor....
http://www.ebay.com/sch/i.html?_kw=motor+tyj
02/26/2014 12:20 PM
good idea, I wonder about continuous duty?
Re: Electric Motor for Rotating Cylinder
02/26/2014 12:05 PM
"As you can see in the picture the cylinder (4'' diameter x 8'' long) is connect to a electric motor"
What picture?
02/26/2014 12:14 PM
This may or may not be the picture....
02/26/2014 4:48 PM
02/26/2014 5:53 PM
Why not have the wheel with a hub motor and eliminate the cylinder and drive all together?
02/26/2014 12:17 PM
how much weight are we talking about??
02/26/2014 4:54 PM
on top of the cylinder will be a car tire, I guess about 7/8 pounds
02/26/2014 5:00 PM
A typical tire weighs 17-25 pounds. Add the weight of a wheel and you're at 40 pounds.
02/26/2014 12:20 PM
Typical artist. Don't know what you want, just what you don't want.
This↓ should be quite enough for you:
Vintage 1957 L.A. Goodman Steam Trains Racing Motion Lamp ...
02/27/2014 12:56 PM
Your answer is to insult the poster if you can't provide them an answer because the poster isn't providing all the information ( in your opinion maybe) necessary for your response. If you don't have an answer to the subject, ignore the post. Your unprofessional, rude and obnoxious comments are meaningless and offensive.
Good Answers: 266
02/26/2014 12:51 PM
Just adjust the heat applied to get the desired rotational speed.
Can't get much quieter unless you use a noisy candle.
Good Answers: 183
02/26/2014 1:29 PM
I see no picture. May be I am blind or it is a transparent one.
There are means and ways to make it insonor even if it is an electric gear motor.
You can also use a weight motor as in old clocks, some run for a week!
02/26/2014 4:49 PM
02/26/2014 1:41 PM
What happened to your vertical lift motor project of 2010 ?
http://cr4.globalspec.com/thread/53092
02/26/2014 4:52 PM
Thank you to ask me, I used a gear electric motor and it worked well but it's too noise. Here the project I have in mind
Good Answers: 70
02/26/2014 10:53 PM
I'm curious as to what your going to do with your design? It sure looks like the mounting and spin up motor for the WWII Bouncing Bombs
02/27/2014 9:16 AM
Great link ! I remember them, nice to see the details. There was a movie made about them wasn't there? Dam Busters I think it was called. For this application OP is talking about only 3 rpm I think, as opposed to the inventor's specified 500 rpm. Any useable implementation of the original design IMHO would be "difficult" and not something that would be aided by suggestions on this site.
Good Answers: 70
02/27/2014 3:25 PM
There was a movie about it and was called, "The Dam Busters" (1955) and NOVA did a recreation of the mission using Buffalo Airway's DC 4. What a genius conception and to pull it off, simply brilliant. And they did spin them up to 500 rpm (backwards to the flight path). I understand the Germans captured one bomb from a plane that was shot down and tried to reverse engineer it, but didn't understand why the reverse rotation!
02/26/2014 11:22 PM
A record turntable motor could work. They are silent, and some are belt drive.
Good Answers: 153
02/27/2014 7:16 AM
Check out drum motors. These are motors built into a conveyor roller. Various manufacturers but try Interroll or Vandegraff,
03/11/2014 10:18 AM
Thank you to all for the suggestions, I did some modifications from my first idea and I show how the project it will be, all the turntable and microwave motor are fine but it will be not powerfull enought as you will see in my mew image to make turn a car tire that weight about 20 pound. Seem to me a windscreen wiper motor it is a compromise for price and noise. Do you know any web side were I can find belt, pulley, flange to enclose the motor, cylinder, belt?(the electric motor, belt will be not visible but inside a box, the tire will be visible)
Thank you
Good Answers: 70
03/11/2014 2:41 PM
You might take a look at this, U.S. Patent 3633295, Rotating tire display. Some one may have beat you to it?
Register to Reply 26 comments
dj95401 (3); Fredski (2); jhhassociates (1); klebe (6); LongintheTooth (2); lyn (2); nick name (1); ozzb (1); PWSlack (1); SolarEagle (3); Steve Batey (1); tcmtech (1); Tornado (2)
