Previous in Forum: Electric Motor for Rotating Cylinder   Next in Forum: AISI 410 Vs 420
14 comments
Calculation of Pressure Versus High Water Column
02/26/2014 9:40 PM
Dear all, I wants to know any formula / thumb rule to calculate / confirm the pump head. One pump is running with presure of suction and discharge 1.2 / 3.4kg/cm². how to find the suction pressure of pump with system standing pressure (water column) is 2.0kg/cm² and pump head 25mtr. what is basic formula for calculate the pressure of vertical water column and pressure versus vertical water column.
Pathfinder Tags: water column versus pressure
Re: calcultion of pressure versus high water column
02/26/2014 10:22 PM
Re: calculation of pressure versus high water column
02/26/2014 11:04 PM
It just adds up doesn't it?
02/26/2014 11:08 PM
> it just adds up, doesn't it?
sum times
Toto, I've a feeling we're not in Kansas anymore
02/26/2014 11:47 PM
1 psi ≡ 2.31 feet
02/27/2014 5:49 AM
That stuff is O-level Physics - variaton of pressure with depth, that sort of thing.
Good Answers: 181
03/01/2014 5:45 AM
It's raining here at the moment. Who can I blame it on?
Good Answers: 137
02/27/2014 7:34 AM
Not clear what you're asking. As #5, calculating (static) pressure from water column is elementary physics, but that doesn't give you actual pressures at pump suction and discharge, you need to allow for pipe friction.
Is there just one set-up here, with system standing pressure (water column) 2.0kg/cm² and pressure of suction 1.2kg/cm² (the difference being friction loss) or are you trying to work out change in performance if suction pressure changes?
What do you mean by pump head, is this generated head?
02/27/2014 11:08 AM
  • I wants to know any formula / thumb rule to calculate the pump head. what will the head of pump, if it is running with 1.2 kg/cm² suction and 3.4 kg/cm² discharge pressure.
  • what will the pressure at bottom of 10 mtr high water column.
  • how to find / guess / the suction pressure of pump before start. If any pump of 25 mtr head is equiped in inclosed circuit and circuit is having 2.0kg/cm² standing pressure.
Good Answers: 137
02/27/2014 12:07 PM
That's just a repeat of your original post. Need answers to my questions to try to help
Elementary physics, but if you can't do that, it's 1 barg near enough, if everything's static and open to the atmosphere
First time you've mentioned closed circuit, is it a heating system? For a closed circuit you need either a header tank or an expansion vessel, to cater for water expansion (even if it's not a heating system). The connection to the header tank or an expansion vessel should be close to the pump suction, so that is the point of minimum pressure. The header tank should be high enough to provide pump NPSHR plus a margin (or expansion vessel pre-charge to provide it). The pump does not see any static differential head, only friction. Other than that you need to give more detail.
02/27/2014 5:49 PM
LynDoor™Industries Guess-O-Matic head calculator can solve those pesky head calculation problems.
It's management approved for budgeting and proposal calculations.
For an additional fee, it can be calibrated and certified.
And various multipliers can be assigned to each ring for added flexibility, depending on customer astuteness level. They are BS, MS and PhD.
02/27/2014 11:20 PM
Hi,
25 m head = 2.5 bar approximately.
Re: Calculation of Pressure Versus High Water Column
02/28/2014 2:05 AM
Hi dspataw
http://joshmadison.com/convert-for-windows/
This is a free program, but I note under "Pressure" it doesn't have a direct conversion from water head in feet to PSI or m to Kpa. You can program this in yourself. 1m head = 10.19Kpa. Tony
The nice thing about Standards is there are so many to choose from.
Good Answers: 137
02/28/2014 7:06 AM
It doesn't have a direct conversion from water head in feet to PSI or m to kPa because they don't have the same units. Pressure = h*ρ*g (in consistent units, extra factor otherwise) so density ρ is needed, and the calculator doesn't have the facility. Also g, but that's usually taken as constant.
But I'm not sure the OP is only asking for head to pressure conversion, he seems to want somebody to analyse his system.
02/28/2014 8:57 AM
Yes you are correct, I've spent too much time with water to realise there are are densities. Anyhow the the calulators good isn't it and I hope g continues to stay constant (stupid bloody newtons). Tony
Register to Reply 14 comments
Codemaster (3); dspatawat (1); IdeaSmith (1); lyn (2); MagicWand (1); PWSlack (1); Tonymech (2); TonyS (1); Tornado (1); ur_n73b (1)
