Previous in Forum: Space for Video on CR4   Next in Forum: PROBLEM: How Far Will THIS Move?
D Tube Boiler Question
03/01/2014 9:26 PM
How do we retube a D tube boiler.
Re: D tube Boiler.
03/01/2014 9:41 PM
Contact a boiler repair facility.
Hire a re-tubing technician.
The boiler manufacturer may publish instructions but with no information, there's not much to do for you.
Maybe if you told the forum the maker and model, someone might help.
Boiler Re-Tube Services | NDT Preperation | Boiler Stripdown ...
SPECIFIC RETUBE INSTRUCTIONS 70 TO 150 H.P. ... - Parker B
Re: D tube Boiler.
03/01/2014 10:07 PM
Sounds a bit stupid my question, but all what i am looking for is idears to get the job done faster.
thanks lyn for your contribution.
Re: D tube Boiler.
03/02/2014 9:00 PM
you have option of replacing tubes by bending some tubes and welding it, i do not see any other good solution
Re: D tube Boiler.
03/01/2014 11:31 PM
Using the same type and size of tubes, bend a bunch of them to the same dimensions as the originals. Cut out the old ones, and weld in the new, following correct and required procedures.
Good Answers: 444
Re: D tube Boiler.
03/02/2014 8:45 AM
How do we know how to help you if we know nothing about the boiler besides the shape of the tube? All the conditions about the boiler need to be known because the level of skill required varies according to the temperature and pressure inside the tube along with the firing conditions outside the tube.
If all you want is a "hint" to make the job go quicker then higher a competent company to do the work for you. This is not the same as bending some tubing and welding an exhaust system for your car; do it wrong and you'll be doing it over...and over...and over.
Re: D Tube Boiler Question
03/02/2014 7:25 PM
are you sure that a good cleaning Will not work, must you replace tubes?
Register to Reply 6 comments
babasiga (1); Fredski (1); lyn (1); manojCC (1); RAMConsult (1); Tornado (1)
