Previous in Forum: High Volts in Neutral & Earth   Next in Forum: Neutral Path
15 comments
Problem with RLC Circuit
03/05/2014 8:47 AM
In the circuit shown below, find the value of the resistance R that is necessary to make the magnitude of V equal to 3 volts.
Can any one please help me to solve this out?
Pathfinder Tags: RLC
Re: Problem with RLC Circuit
03/05/2014 8:56 AM
Oh, yes. The class tutor would be the first port of call, particularly as loads of variables remain undefined. Try there.
03/05/2014 9:28 AM
R can be anything you like, as you haven't defined V. So just call it 1 (remembering not to specify any units).
03/05/2014 9:46 AM
Magnitude of V is 3.
And given, e(t)=5sin(10^6t) volts
Then what happened?
Good Answers: 131
03/05/2014 9:53 AM
This should have been covered in class by your instructor (or did you skip that class?).
This should be explained in your textbook (or did you spend your textbook money elsewhere?).
This is not a homework site. Do your own work! You will never learn if someone spoonfeeds you the answers.
03/05/2014 10:36 AM
Yes, yes you've already said how big it is. But you still haven't said what V is!!! Let's assume it's the voltage across R. Now let's change our minds, and assume it's the voltage across L. Now let's assume it's the voltage of my flashlight battery, just to make it a bit more tricky.
03/05/2014 10:13 AM
please!
03/05/2014 10:18 AM
Good Answers: 203
03/05/2014 10:29 AM
I did my academic homework years ago. You do your academic homework now!
How do you know that I won't dress up a wrong answer to make it look like the correct answer? If you choose it you sink! Do the work yourself and find out what is right and what is wrong. Besides all that, I charge an price you can't afford!
Good Luck, Old Salt
03/05/2014 11:51 AM
42
03/06/2014 1:08 PM
42 is a good answer
Good Answers: 42
03/05/2014 12:00 PM
The voltage V it is not the supply voltage e(t)=5*sin(10^6*t) but the voltage downstream from R as shown, I guess. If w=10^6 rad/sec then you can calculate the reactance and current in complex.
Julius
03/05/2014 1:29 PM
03/05/2014 1:33 PM
Please read the forum rules and your textbook notes- homework questions are NOT allowed on CR4.
03/06/2014 4:59 AM
The correct answer for £5 is, yourself. You may also phone a friend or ask the tutor.
Good Answers: 117
03/06/2014 7:44 AM
nice resonant circuit. Do your own homework.
Register to Reply 15 comments
7anoter4 (1); Anonymous Poster (1); bacthiar_ahmed (1); Fredski (2); IQ (1); jack of all trades (1); JohnDG (2); Kilowatt0 (1); old salt (1); PeterT (1); PWSlack (1); SolarEagle (1); Yusef1 (1)
