Previous in Forum: Pipe Wall Thickness Calculation   Next in Forum: Torque Calculation
Test Block in AMCA Standard
03/08/2014 1:24 AM
AMCA specifies the term "Test block" as a design point of fan.
Please advise the meaning of this "block".
Best regards.
Pathfinder Tags: test block
Re: Test block in AMCA standard
03/08/2014 2:23 AM
"In addition to the fundamental volume specifications, combustion
process fans, particularly larger fans, are often specified for
two conditions . . . actual and test block. The actual condition
is the calculated volume (including excess air) and pressure
requirements. The test block condition is a theoretical duty
that includes some safety factor beyond the actual volume and
pressure requirements. The fan selection for the application
should be capable of meeting both conditions with good efficiency,
economy, and stability. Whenever possible, the actual condition
should represent the most efficient point of operation for the
fan selected for the application. "
http://www.mpair.com/library.active/nyb.engineering.letters/engltr10.pdf
