Previous in Forum: EOT Cranes   Next in Forum: Test Block in AMCA Standard
10 comments
Pipe Wall Thickness Calculation
03/07/2014 6:17 AM
Can anyone help me with an Excel sheet for Pipe Wall Thickness Calculation based on British Standard, BS EN 13480.
Thanks in advance
Shyam Prasad
Re: Pipe Wall Thickness Calculation
03/07/2014 6:24 AM
What is your contribution to the members of this forum?
03/07/2014 7:39 AM
Search this site, I believe this may have been brought up in the past.
Good Answers: 109
03/07/2014 8:43 AM
Where.?
Where?
Where is your pride?
If it was me (and it is obviously not) I would take pride in calculating this myself!
Wall Thickness is always OD -ID. Every standard will recognise this.
AND
You can do this! So do it!
Good Answers: 26
03/07/2014 9:48 AM
Wall Thickness is always OD -ID.(OD-ID)/2.
Good Answers: 109
03/09/2014 9:21 AM
Well I have to find my pride then!
Yes you are right!
Problem is I have a little excel program that does this for me . . .
03/07/2014 10:10 AM
Google: pipe wall thickness calculation excel; get 64,100 results.
Really, don't be lazy, be smart.
03/07/2014 8:30 PM
t = PD/2Sallowable; then do a LOOKUP function to select the next larger standard pipe thickness.
03/07/2014 8:39 PM
How to check your calculations. The OD must always be larger than the ID.
03/09/2014 1:43 PM
Pipe schedules already have this information tabulated, Boss. The procedure is one of selection rather than calculation. You just need the maximum pressure, the temperature range, the line size and what's in it. The rest you can do with your local piping distributor using Alexander Graham Bell's wonderful telephone apparatus.
Good moaning!
03/09/2014 1:56 PM
So many of our newcomers, AP's especially, seen to think the problems of the world can be solved with a mathematical formula without the application of any common sense.
Or a phone call to their piping supplier.
Or a web search.
This lack of initiative seems to begin in school, that is for those who went to school.
Register to Reply 10 comments
Anonymous Poster (1); Crabtree (1); IdeaSmith (2); lyn (3); phoenix911 (1); texasron (1); Tornado (1)
