Previous in Forum: Test Block in AMCA Standard   Next in Forum: Uneven Radial Clearance of Labyrinth Seals
12 comments
Torque Calculation
03/08/2014 1:49 AM
We use the formula , T=9550x motor kw X F.O.S / Motor rpm to find the brake torque. What is the significance of the constant " 9550" and how is that deduced ? Thank you.
Pathfinder Tags: Mechanical calculations torque.
Re: Torque Calculation
03/08/2014 2:18 AM
Just how it works out....
"The nominal torque of the motor TN' is the torque developed by the motor at rated speed n, while delivering the rated power P. The relationship between these three parameters is
TN' = 9550 x [P/n] (Nm)
where P = Power (kW)
n = motor speed (rpm)
Alternatively, torque TN' in kgm can be given as
TN' = 974 x [P/n] (kgm)
http://www.steelofab.net/high_efficiency_motors.html
Good Answers: 137
03/08/2014 10:08 AM
In SI units, T (N.m) = power (watt)/speed (rad/sec). If power is in kW and speed in rpm, conversion factor is 60*1000/2/pi = 9550. You didn't tell us your units for T, but N.m is usual.
What is F.O.S ? It's not needed.
03/09/2014 11:53 AM
Thank you. F.O.S is Factor of Safety.
03/09/2014 2:31 PM
Good thing you said that, because sometimes it means something else....
05/30/2023 9:56 AM
Good Answers: 70
03/08/2014 9:35 PM
Here's the link to Konecranes, http://www.konecranesusa.com/
In other words contact Konecranes, replacing the motor(s) with something other than OEM that the equipment designed for could lead to a real can of worms.
Good Answers: 137
03/09/2014 9:27 AM
Am I missing something? How did cranes and replacing motors get into it? I thought OP asked a simple question and got simple answers!
Good Answers: 70
03/09/2014 12:34 PM
If you look at Wahsoo's pass questions, #1 and #2, you'll see he has an overhead crane that has some major issues with traveling. Breaking drive axle, wheel collar rubbing, and rail sides are worn out. Which all leads me to believe that he's wanting to re-size the drive motor to over come the excess drag caused by everything being askew.
Good Answers: 137
03/09/2014 1:44 PM
OK thanks
03/10/2014 4:45 AM
Good observation. But this question, I asked out if curiosity!
Good Answers: 70
03/10/2014 9:07 PM
I just want people to play and stay safe.
08/25/2017 3:38 AM
The Horse Power or KW is calculated on the basis of work done in a given time.
In FPS system the H.P is ( 2 X (phi or 3.14) x N x T )/33,000 where N is speed in RPM and T is Torque in Lb.Ft.
In Metric System the H.P is ( 2 X (phi or 3.14) x N x T )/4500 where N is speed in RPM and T is Torque in Kg.M.
If you derive the above equation from fundamentals, you will get the constant 33,000 for FPS system and 4500 in Metric System.
Now the Torque in IS system (International Standards system) is reckoned as NEWTON-METRE or Kilo Newton-Metre.
If you derive from the fundamental you will have the constant of 9550.
DHAYANANDHAN.S
Register to Reply 12 comments
Anonymous Poster (1); Codemaster (3); dhayanandhan (1); dj95401 (3); SolarEagle (1); Tornado (1); Wahsoo (2)
