Previous in Forum: ASME B31.3 Process Piping Hydrostatic / Leak Testing   Next in Forum: Ceiling Fan Direction and the Change of Seasons
14 comments
Ultra fine abrasive paper for polishing metal?
06/12/2007 9:47 AM
what is the finest grade of abrasive paper (+ 1500 grit/ 4 microns) availiable and
where can it be purchased? (for polishing metal)
"It Is By Giving, We Recieve"
Good Answers: 40
Re: Ultra fine abrasive paper for polishing metal?
06/12/2007 10:18 AM
Typically Wet/dry sheets up to 6000 grit is used in the Auto Body repair. Any hardware store that has auto body repair supplies will carry it.
Another way to polish metal is 0000 steel wool
To get a gloss finish, the best finish is with a buffing wheel with 'jewelers rouge'.
06/12/2007 11:32 PM
One of the best polishing compounds I've used is Simichrome - works well on all metals and many plastics. Also builds up well in a cloth; I've used several times on a part still in the lathe. Probably not OSHA friendly but very effective!
06/12/2007 11:39 PM
McMaster-Carr also sells emery cloth up to 2500 grit and ultra-fine crocus cloth that is used for polishing soft metals such as gold. Some of the Scotch-Brite pads work well on harder metals.
Good Answers: 94
06/13/2007 5:36 AM
We use diamond polishing compounds for high quality finishes. Typically we use 2µm compounds on stainless for a mirror finish.
06/13/2007 7:47 AM
I purchased a silver polishing cloth that worked better than any abrasive or chemical I have tried for polishing. It made very easy work of a large polishing job.
06/13/2007 8:30 AM
That would be great! Where can I find this silver polishing cloth?
06/13/2007 12:30 PM
Beware - silver polishing cloths are treated with a chemical specifically designed to remove silver tarnish. Not sure what exactly this chemical is or how it may affect other metals.
06/18/2007 8:36 AM
06/13/2007 3:42 PM
"That would be great! Where can I find this silver polishing cloth?"
Red rouge polishing cloths may be found at large jeweler's or better yet at a Jewelry Wholesale Supplier. The red rouge is a very very fine polishing agent.
Red Rouge and Other Polishing Agents
06/13/2007 4:11 PM
I think my wife bought it from Walmart. That does not mean I in any way advocate shopping there.
06/13/2007 4:20 PM
"I think my wife bought it from Walmart."
If you can't find it at the super Notions-Grocery, try one of the BIg Box H.I. Stores!!!
Good Answers: 18
06/13/2007 3:10 PM
Pepsodent toothpaste works like a charm on everything from metal to plexiglas.
06/14/2007 8:36 AM
What finish are you starting from? Alumina slurry is used to polish metallurgical samples. A .2 micron finish but it is worked down to in stages.
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
06/18/2007 8:35 AM
T-Cut liquid can be used with bare metal, as can Brasso (usual disclaimer).
Register to Reply 14 comments
Anonymous Poster (3); Bill (1); erssk (1); madscientist (2); Nigh (1); PWSlack (2); Stirling Stan (2); techno (1); wilycoyote (1)
You might be interested in: Abrasive Belts
