Previous in Forum: What is the Difference Between Bkw & kw   Next in Forum: Powerfactor of LED Lamps
28 comments
Protection Relay Settings
03/14/2014 2:57 PM
Hi All I want to know that what are the general setings for protection relays. Relays as below Under overvoltage Under over freq Reverse power Diff realay Ground fault curent Overcurent
Pathfinder Tags: protectin
Re: protection relay settings
03/14/2014 3:11 PM
They're whatever the general says they should be. That is unless you're on a ship. Then it depends on whatever the admiral says.
Removing the jocularity from my point, it all depends on where and how these relays are used. That is exactly why these relays can be adjusted.
Re: Protection Relay Settings
03/14/2014 4:17 PM
Co-Pilot Roger Murdock (to Capt. Oveur): We have clearance, Clarence.
Capt. Oveur: Roger, Roger. What's our vector, Victor?
Dr. Rumack: Captain, these passengers don't have much time. How soon can we land?
Oveur: I can't tell.
Dr. Rumack: You can tell me, I'm a doctor.
Oveur: What I mean is, I don't know.
Dr. Rumack: Well can't you take a guess?
Oveur:...Not for another two hours.
Dr. Rumack: You can't take a guess for another two hours?
Oveur: No what I'm saying is we can't land for another two hours.
Good Answers: 445
03/14/2014 5:59 PM
Sure! Undervoltage relay shall be set lower than the Overvoltage relay, Overvoltage relay shall be set higher than the Undervoltage relay; Underfrequency relay shall be set lower than the Overfrequency relay, Overfrequency relay shall be set higher than the Underfrequency relay; Reverse Power relay shall be set in the opposite direction of other relays; Differential relay shall be set differently than the other relays; Ground Fault relay shall be set to detect who's at fault; Overcurrent relay shall be set higher than the past relays.
03/14/2014 8:56 PM
The 4X100 meter relay will require careful baton settings.
03/15/2014 12:20 AM
Dear Fred,
We have old 10.2 MW generator & we have to recommission the generator. Kindly help me & suggest me the protection relays settings...
Good Answers: 266
03/15/2014 8:57 AM
Hey don't all you guys have that service manual in your back pocket. Now what did he say the make, model and serial number was anyway.
03/16/2014 2:32 PM
What protection relays are you using?
Given your previous questions it would be better and safer to hire a consultant who can analyse your application and provide you with the correct settings. Any opinion (other than the most basic generalisation) we post here is unlikely to be correct due to the complete lack of information.
03/16/2014 3:06 PM
You can lead a horse to water, but you can't change his spots. lyn
03/16/2014 3:14 PM
Totally off topic, I got to use my previous boss's one he used on clients at work last week.
"You can lead a horse to water but you shouldn't be expected to suck on its ass to get it to drink"
It made my point then by the way.
03/16/2014 9:40 PM
LOL ROFL I'm going to steal that line in the not too distant future.
03/16/2014 10:23 PM
Really helps to put the stops on an argument so you can get your point across if the other person just isn't listening, especially if the other person isn't expecting it from you.
It pays to have all your facts straight thou so you can talk your way out after saying it. Use it only for good my young Padawan.
03/17/2014 10:05 AM
If it's a recommission, then the settings should be the same as they were before the work leading to the recommission started. What do the original commissioning records say?
03/17/2014 10:24 AM
5 if(it's broken or not working) then 8 else 20
8 gosub 1000
10 if(you buggered about with it) then 100 else 20
20 rem you got away with it
30 end
100 rem you idiot
105 gosub 1000
110 if(someone saw you bugger about with it) then 200 else 120
120 rem you're in luck
130 dump it in the skip
140 end
200 rem you idiot
205 gosub 1000
210 if(you can blame someone else) then 130 else 300
300 rem you are really in deep doodoo
305 gosub 1000
310 if(you can hide it) then 320 else 130
320 no problem
330 end
1000 subroutine panic
1010 panic
1020 return
03/17/2014 10:51 AM
AND IF IT MOVES, SALUTE IT; IF IT DOESN'T MOVE PAINT IT.
They never speak softly in the military.
Good Answers: 102
03/17/2014 11:40 PM
What a beautiful ballad....made me laugh and cry.....poetic logic.
Good Answers: 34
03/17/2014 10:43 AM
Is this complete or you require any accessory or control panel or AVR panel, protections or PLC or any other help. We are specialized in this field. In 2007-08 we did similar services for a 5MW 6.6kV MAN BCC (now ABB) Steam Turbine Generator set bought by Asian Biggest Mushrooms Farm in India.
03/15/2014 12:22 AM
very funny you should be serious in this forum to attract epople to use this forum & if anyone is new in this field so do not make fun of him...
Good Answers: 102
03/15/2014 3:47 AM
Friend,
Learn to relax and don't panic.
Humour is better than a box about the ears to demonstrate how vacuous your request for help was.
The recommissioning of a 10.2MW genset is not a minor undertaking. There will be documentation that specifies what the nominal operating parameters should be, aka "what you want", and what permissible deviation from this ideal, aka "what you really don't want" is acceptable for your location and most likely very specifically for the installation that is now in your face.
Big job for a newbie. Enjoy the challenge.
Sumairali, what documentation/records/specs/scope of works/surveys/audits.... do you have? What have you Googled so far? What colour is the turbo encabulator
Where are you?
Good Answers: 102
03/15/2014 3:30 AM
True humour.
OP seems to have been dropped in the deep end.
He will must learn fast or drown.
03/15/2014 12:29 AM
If you have the correct manuals and operating instructions available, you should not have to ask these questions.
Do you have these manuals and instructions?
Have you read them?
Do you understand then?
Do you have anyone on staff who understands them?
Have you sought professional help?
Have you asked the manufacturer?
What have you done?
No one here can help you unless you give them some useful information, which you have not done, so far.
Good Answers: 181
03/15/2014 11:54 PM
"Have you sought professional help?"
If I hang around this forum much longer I think I'll be needing professional help!
03/15/2014 11:57 PM
Enter forewarned.
The post you read here may be hazardous to your sanity.
03/15/2014 5:13 AM
try this: http://www.gedigitalenergy.com/Multilin/notes/artsci/index.htm
India - Member - New Member
Good Answers: 164
03/16/2014 11:17 AM
You won't go wrong if you follow the cardinal rule that the relays should not trip at normal values and must trip at when they reach dangerous levels. You are in the best position to judge hwat are dangerous levels, nobody here can help i think. For example, if the normal voltage is 415V and, if it becomes 430V the situation becomes dangerous, then the relay must trip before 430V, preferably say 420V.
Good Answers: 34
03/17/2014 5:49 AM
For Under Voltage, Over voltage, Under Frequency and Over Frequency Protections are set to rating of equipment.
That means look at data sheets of equipment connected.
Assume that Voltage Limit is +/-10% and Frequency is +/-3% (which are normal parameters).
If your protection relays are 2 element, set first element at above limits with time delay as back up and second element at 15% more with time delay of few seconds (Less than 4 to 5 Secs). Best is to see the recovery time of DG Set at block loads. This time delay is to avoid nuisance tripping.
The reverse power relay shall be set at 80% of mechanical efficiency of the Diesel engine. You need Rev Power only if the DG set is synchronized with any other source. If single operation leave it by passed.
Mechanical efficiency means the losses (which is equal to power required to turn the Engine without load), when the Engine is rotated without producing any work - It is mostly friction losses.
Time delay of Rev Power is set to avoid nuisance tripping just after synchronized and can be 10 Sec or more.
If you do not find data above mechanical efficiency of engine - set it at 3% of DG rating 10 Secs.
Generator Earth Fault relay (Restricted Earth Fault relay) shall be set at lowest possible setting and time - normally it is instantaneous relay (max. 20 m secs - 1 cycle for 50HZ). Reason being that probability of Earth Faults is maximum and shall be cut out in minimum of time to avoid any damage.
The DG you are talking appears to be having Neutral grounded through resistance - in this case earth fault is very low and needs accurate CTs (Toroidal CTs at either end to sense fault).
Over current relays are set as a back up to outgoing feeders. That means operating time of O/C relay shall be at least 100 to 120 mSec more than feeder protection.
I do not know which country you are in. I am in India and I supply control synchronizing and protection panels for power plants. Our recent job was in supply installation and commissioning of similar panels for power plant in Sudan for EL Genena and El Fasher Power Plants. You can contact us for any help.
03/17/2014 2:17 PM
Thanks alot ok i wil contact u if required...
Good Answers: 122
03/20/2014 9:44 AM
Protection relay settings are dependent on the system design, system condition, and equipment requirements.
Suggest you contract with a competent, systems protection enigneering analyst before proceeding to identify your application needs/requirements.
Failure to do this can and will result in severe equipment damage and/or personal injury possibly death.
06/10/2024 9:47 AM
It would help to know the equipment manufacturer's telephone number. That would enable some calls to be made for advice (invitation declined).
Register to Reply 28 comments
beentheredonethat (1); jack of all trades (3); kvsridhar (1); lyn (5); ozzb (1); powersolutionsFBD (2); PWSlack (3); RAMConsult (1); redfred (3); SHOCKHISCAN (1); sumairali (3); TonyS (1); Wal (3)
