Previous in Forum: Gland Steam Condenser Venting Condensate Too Much   Next in Forum: Avoid Dust Entering To A Tank
Heat Exchanger Tube Material
03/24/2014 1:11 AM
Dear All,
We are using SA 179 Tubes for Heat Exchangers. One of Our client commented to change it to SA 106 Gr B and also asking the reason for Using SA 179 Tubes.
ASME SA 179 clearly specifies the Seamless Low corbon Heat Exchangers Tubes. But is there any othet Technical reason for using SA 179?
CAN SA 106 Gr B Pipes can also be used in place of SA 179.
Regards
Rakesh
Re: Heat Exchanger Tube Material
03/24/2014 4:13 AM
If you are manufacturer you should have access to the standard or make it available in case there is a question.
Available from ASTM.ORG
http://www.astm.org/Standards/A179.htm
http://www.astm.org/Standards/A106.htm
also note possible differences between ASME and ASTM
http://www.amerpipe.com/products/seamless-carbon-pipe/a106-grade-b
Good Answers: 38
03/24/2014 7:15 AM
Rakesh....
You must first understand the nature of ASTM standards and the differences between pipe and tube.
SA 179 refers to a specification for carbon steel TUBING.. SA 106 Gr B refers to a commonly used specification for carbon steel PIPING. Piping is not the same as tubing.
http://www.engineeringtoolbox.com/pipes-tubes-d_347.html
03/25/2014 4:41 AM
Thank you for your reply, I know that SA 179 is cold drawn tubes and SA 106 is Hot finished pipes.
I can use either pipe or Tube if the thickness with stands for design Temperature .its only distributing Heat Transfer area in to pipe Length.
But every where SA 179 tubes are used for Heat exchanger. Is there any specific reason. We use SA 179 and recently we have received few offers from vendor and every one using SA 179.
Is there any Technical reason behind the selection of SA 179.
Regards,
Rakesh Reddy
Good Answers: 104
03/24/2014 8:31 AM
What size do you require? AFAIK, SA106 is not available in tube sizes.
03/25/2014 9:17 AM
You do not state the diameter of the tubes, so I am assuming you are talking about 3/4" to say 1.5" OD tubes. Without looking up the specific tolerances in the respective ASTM/ASME standards, I say the tolerances for the SA106 pipe would not work for the tubesheet drilling and tube groove expansion into the tubesheet holes. I am sure the SA179 tolerances are much tighter which allows the tubesheet holes to be drilled to a much closer size to the Nominal Tube OD.
bigg (1); IdeaSmith (1); Mechanicalmark (1); MJCronin (1); RAKESH REDDY (1)
