Previous in Forum: Heat Exchanger Tube Material   Next in Forum: A Question About Elastic Modulus of Fe
15 comments
Avoid Dust Entering To A Tank
03/24/2014 10:52 AM
Hi,
We've built an atmospheric tank out in the open, so when this is being emptied exist the possibilitie that dust enters to the tank through the vent duct (this involves contamination of the product).
A solution could be install a ventilator and arrive with air to the venting duct to avoid the dust to enter. Is this a good idea? What type of ventilator could help?
Re: Avoid Dust Entering To A Tank
03/24/2014 11:13 AM
Don't know about a ventilator. I'd've thought a HEPA filter would be appropriate.
03/24/2014 11:59 AM
If its a liquid tank, one has to be concerned about any restrictions on a breather on a tank.
Does not take much for a tank to collapse.
I not short what is in the tank, sounds like the environment is not sanitary????????
If dust is critical, I have seen bladders on tanks to handle this.......
Also at what rate is the tank drained?
03/24/2014 2:27 PM
Hi,
There is final product in the tank, so any external element could contaminate what is inside (dust, insects). The tank is in the open air.
The tank is being drained at 5 m3/hr.
Good Answers: 102
03/24/2014 10:48 PM
There's another GA for you.
A form factor similar to this would be appropriate...
The tank's breather allows air to enter as the tank empties to prevent collapse. It also allows air to exit when it is being filled to prevent opposite as well. It breathes in and out.
The one shown is not too good if it gets wet. Some sort of weather proof housing would be a good look.
Good Answers: 18
03/24/2014 11:31 AM
Hi ChemistUSX,
What size and shape is the tank? What is the product? What size, and shape is the port on the tank you want to fit the ventilator to?
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
03/24/2014 11:50 AM
Hi John,
Thanks for the answer
Size of the tank: height: 5mts/ Volume: 50 m3
Shape of the tank: Cylindric
Product: Sugar Concentrated
I want to avoid the entering of dust to the venting duct. The shape and size of the venting duct is an U-figure of 3 in. diameter.
Good Answers: 266
03/24/2014 12:03 PM
Sealing the tank and bring air to to exchange it may not be the way to go. Temperature changes in the environment may cause stress on the tank as the material expands and contracts in sealed environment.
They make filter vent caps.
03/24/2014 12:08 PM
There is nothing wrong with a sealed tank as long as you have a bladder to compensate.
But, if its a sugar product, it would be great if we had more information to make a more intelligent response.?????
03/24/2014 3:01 PM
The situation that i explained is like the next picture
http://tinypic.com/view.php?pic=2zxpf12&s=8#.UzB_WazLe_0
So, if I understood well, adding air in the breather could result in a pressure rising in the tank? is it enough to produce collapsing?
03/24/2014 3:40 PM
No, what causes the tank to collapse is the vacuum created as the tank drains......
And if the tank is open air, and the type of product......... insects are going to love that sugar........
Just throwing this out there.
You may have to look at your environment as a whole......... If you have a food product. You have a lot of issues that may have to be addressed.
Do you have a Hazard analysis and critical control points (HACCP) program?
If not, you this is what you should be looking into......
03/24/2014 3:28 PM
Another installation that has not gone through a formal HazOp Study? How sad.
Good Answers: 109
03/24/2014 3:58 PM
You need to contact a company that specializes in controlled venting of tanks. There are companies like Millipore and Micropure that would be more than happy to design a sell you products. They will design with your full requirements of drain rates and sanitation. You may also want to look to drain guards.
Good Answers: 117
03/24/2014 11:42 PM
I would use a tank the same size as the sugar tank, but with water in it. Joined by a pipe at the top. As you fill the sugar tank, the water tank would drain. (where? Is there lots of filtered water available?) As you emptied the sugar tank, you fill the water tank. (Help push the sugar solution out. ) This would create an exchange of air without releasing or drawing any of the uncontaminated air into the environment. Another solution would be a very large "compressor tank" which would compress the air as you filled the sugar tank. Lots bigger, or you might overpressurize either of the tanks! Be very careful of using filters...a clogged filter can collapse a perfectly good tank!
Clearly filters are better...but I figure an out of the box solution might be fun.
03/25/2014 2:12 AM
We use Sartorius and Millipore bacterial filters on tanks containing sterile fluids for this purpose.
bioramani
03/26/2014 12:41 PM
Install a vapor equalization line from the head-space of vessel you are emptying to the head-space of vessel(s) you are filling. The vapor being displaced in the tank(s) or drum(s) you are filling will flow back to the tank you are emptying.
This is a requirement for hazardous vapors.
There are 10 kinds of people in the world.... Those who use binary code, and those who don't.
Register to Reply 15 comments
bioramani (1); ChemistUSX (3); jesw55 (1); JohnDG (1); kevinm (1); ozzb (1); phoenix911 (3); PWSlack (1); tribefan1952 (1); Wal (1); Yusef1 (1)
