Previous in Forum: Honeywell Experion DCS Analog Output Card Failure Issue   Next in Forum: Jib Crane
12 comments
Can You Use Molds with Quartz?
04/06/2014 9:00 AM
Im trying to find the best way to manufacture many small quartz fittings and was wondering if it would be possible to use a mold or if each piece would need to be hand blown?
First question here thanks guys!
Re: Can you use molds with Quartz?
04/06/2014 9:36 AM
I'm not sure if quartz has a malleable "plastic" phase state that glass does. If it does I doubt that it will be around one atmosphere of pressure that a person can hand blow. So molding is probably your best bet but you have a lot of research to do.
04/06/2014 10:03 AM
No. Not if you mean "Quartz". SiO2.
If you are referring to fused quartz glass, yes.
04/06/2014 10:22 AM
You imply a very good point here. Quartz is a crystal. Fused quartz is not a crystal. By melting quartz, one has lost the crystal structure and made fused quartz.
04/06/2014 10:28 AM
It a combination of a cynical, literal mind.
We both know what real quartz is.
Whenever I encounter a new poster, I automatically assume they don't know anything.
Usually works well for me.
04/06/2014 1:31 PM
Depends on the shape and quantity.....many and fittings is a little vague....water jets are very versatile....
http://waterjets.org/index.php?option=com_content&task=view&id=119&Itemid=31
I would probably farm out the work for small quantity....
http://www.thomasnet.com/products/quartz-glass-34940601-1.html
Re: Can You Use Molds with Quartz?
04/06/2014 9:15 PM
Can you use penicillin mold with quartz?
Good Answers: 153
04/07/2014 5:17 AM
Here in the UK we try to differentiate the different meanings of the word mold by using spelling. In the US you spell all three definitions m o l d whereas in the UK we spell all three definitions m o u l d. Oops.......
04/07/2014 8:45 AM
molde, mould, mold....
04/07/2014 9:57 AM
Which is why in injection molding, the mold is normally spelled t o o l, which in British spelling would be t o u o u l, unless I've tossed this joke in a coal pail and walked to Newcastle with it.
(I know, I'm mixing the 'coal to Newcastle' metaphor with the visual pun of 'carrying a joke too far,' it's early in this time zone, and my coffee hasn't kicked in yet.
04/07/2014 10:05 AM
You mean it gets worse than this????
Good Answers: 153
04/07/2014 10:24 AM
I could stir up the spelling debate by throwing in the French touiller
Don't worry about crossed metaphors. With the UK mining industry in such dis-array, Newcastle welcomes any coal it can get.
04/07/2014 10:11 AM
I have seen a process where quartz was milled to a fine powder then made into slip then cast and fired.
Register to Reply 12 comments
aDIYguy (1); adreasler (1); Anonymous Poster (1); jhhassociates (2); lyn (3); redfred (2); SolarEagle (2)
