Previous in Forum: Can You Use Molds with Quartz?   Next in Forum: Plastic Shaft Cover
16 comments
Jib Crane
04/10/2014 3:01 AM
Looking into building a shop soon. Was wanting to install a small jib crane. Not sure if I will wall mount or have a freestanding. My question is, what kind of bearing should i use for the top pivot? Was thinking of a tapered "timken" type bearing. I would like to be able to lift 1/2 to maybe 3/4 ton max. I beam arm, with about six foot arm length of reach. I am not an engineer by any means, but would think I would only need a bearing on the upper support as that is where most of the thrust would be. Hope I worded this right, and isnt too confusing. It all sounds legit in my mind! Looking for any advice or from anyone who has built or is knowledgeable in this area.
Thanks in advance.
Good Answers: 266
Re: Jib crane
04/10/2014 9:11 AM
I've used a replacement wheel axle for boat trailer for some small jibs. They come in different sizes for trailer weights. Used the ones which have a square tang for attachment. Which are machined for taper roller bearings. Drilling and tapping two holes perpendicular to each other on the tang. Using these to level the jib in the column. Just have to adapt the arm for the cups of the bearings.
Good Answers: 114
Re: Jib Crane
04/10/2014 9:43 AM
My friends have used ready made ones from http://www.mcmaster.com/#jib-cranes/=rh4yy8
Re: Jib Crane
04/10/2014 5:15 PM
These guys give you drawings with enough detail to build your own using their drawings.
Good Answers: 141
Re: Jib Crane
04/10/2014 10:32 AM
Which bearing will have to "work hard" depends on your design. Unless you want it swing very smooth and easy a ball or roll bearing is an overkill.
I would go for a more reliable bushing ( e.g. bronze). Some ready made solutions do not even use that, but a steel bolt.
Plenty of room here
Canada - Member - New Member
Re: Jib Crane
04/10/2014 11:06 AM
You have to decide before you start your shop of you want a wall mount or free standing unit. If wall mount, make sure you have the design of the building done to accomodate the jib crane. Bearings aren't really necessary. Even commercial units only use high strength bolts or pins for the pivot points.( I have several wall mounted jibs in my shop).
Advantage of free standing is, theoretically anyway, it can be moved anywhere, where as wall mounts will be fixed in one place, unless you have the building designed for multiple locations.
Never stop learning
Re: Jib Crane
04/10/2014 5:49 PM
Purchase a new, tested, prequalified crane from a vendor.
Think of the crane options that you want. Don't go for less than a ton....
Retain all paperwork. Investigate periodic test requirements from the authorities where the crane will be located
There is little to be gained from "designing and building" your own
Good Answers: 102
Re: Jib Crane
04/11/2014 12:18 AM
That would depend entirely on where you were, what was available and on the fabrication skills/facilities on hand.
This is a pretty simple bit of rigging and a very large FOS is intrinsic to that design and the materials being used.......so long as the supporting structure can withstand the moments it will be subjected to that is....and even this can be bolstered.
Re: Jib Crane
04/11/2014 9:03 AM
Agreed. Unless you have the qualifications to do the design, and probably the build as well, best off with an "off the shelf unit" which should come with the proper certifications. Although I have done the design/build thing previously, even my choice is to purchase a unit already "pre-certified".
If you are using this in a workplace that employs people, there are health and safety rules you have to follow, make sure you know what they are and are prepared to follow them.
Never stop learning
Good Answers: 102
Re: Jib Crane
04/11/2014 9:22 AM
Depends where you are.
Rules and standards are a luxury in some places.
Invoking the knack is sometimes the only option.
Re: Jib Crane
04/11/2014 9:38 AM
Yes, rules vary from jurisdiction to jurisdiction, but in my experience, where they are a luxury, the regard for safety(ie., human injury or death) isn't a factor in designing and building things. Only have to look at the factory collapses in Bangladesh, etc., as examples. Maybe it's my "western" world outlook, but I tend to err on the side of caution. Better safe than sorry.
Never stop learning
Good Answers: 102
Re: Jib Crane
04/11/2014 10:22 AM
...but not all the buildings in Bangladesh are collapsing.
...erring on the side of paranoia is not productive.
Re: Jib Crane
04/11/2014 11:12 AM
Somewhat surprising, at least to me. I travelled Bangladesh during my consulting days and what I saw would never stand up to our western codes. I kind of think that we only hear about the collapses where lots of lives are lost, after all, that is all that ever makes the news.
Never stop learning
Good Answers: 102
Re: Jib Crane
04/11/2014 11:40 AM
The collapses make the news.
The successes don't
Yes, you see some shocking things in these parts. What shocks me the most is how bad something can be and still be fit for purpose.
A constant conundrum for me. Fit for purpose V compliance with standards...
I have traveled to the US and seen some right shite that was apparently up to code.
There's the west and then there's the US. US is third world in some regards. Hardly the standard bearer for world's best practices. Cheap mostly. Lucky your LV is only 110V. US construction.... paper, gangnails and plywood....can't go wrong.
Re: Jib Crane
04/13/2014 2:36 AM
I went fully mobile: Engine hoist.
Fine if the ground is solid & level.
Madness is all in the mind
Re: Jib Crane
05/09/2014 5:13 AM
Cranes are mainly used for movement of materials from one place to another in industries, storage areas, power stations, construction sites etc. Cranes differ in their designs widely according to the need for the operational requirements.
Re: Jib Crane
05/29/2014 4:54 AM
Thank you for all your support and comments
Register to Reply 16 comments
Anonymous Poster (1); dvmdsc (1); GM1964 (1); Kevin LaPaire (4); lyn (1); ozzb (1); passingtongreen (1); rosebyrne (2); Wal (4)
