Previous in Forum: Sizing The Coil Spring For Spring Shock Absorber   Next in Forum: Volume of Nitrogen for Leak Testing
15 comments
Bellows Punch Forming Machine Installation
04/09/2014 4:24 AM
HELLO,
please suggest me how to make an effective metal bellow forming machine(simplest one and mechanical type), which type of spocket and chain , lead screwed shaft will be used to up and down the upper bed of machine with the help of 4 vertical lead screw drive(which are driven by motor and chain spocket)
Good Answers: 102
Re: Bellows Punch Forming Machine Installation
04/09/2014 11:34 PM
Seriously?
04/10/2014 12:30 AM
yeah seriously!
have you any idea about this machine, please suggest me
Good Answers: 102
04/10/2014 12:58 AM
I cannot make head nor tail from your description.
Maybe you could reword it and provide some visual aids.
Good Answers: 102
04/10/2014 1:05 AM
You want a machine that makes expansion bellows...
....right?
04/10/2014 3:59 AM
yeah.
Good Answers: 102
04/10/2014 6:49 AM
Ok vj,
A hydraulically powered arrangement comes to mind before any loose arrangement of screwjacks, sprockets and chains.
Why are you building this?
04/10/2014 7:13 AM
because it will be cheaper in cost rather than hydraulic arrangement, even if hydraulic will be easier but for 2 or 3 post with 1500mm stroke of hydraulic cylinder will much costly for me. so kindly give me idea for same
Good Answers: 102
04/10/2014 7:50 AM
It might appear to be lower in cost. What is the cost of failure?
Do a google search for images of bellows forming machines.
Look carefully at them.
Search for some appropriate youtube videos that may show how and what...
You are reinventing the cart wheel vj.
Surely you can get your hands on some salvaged hydraulic actuators and pumps where you are.....
04/10/2014 8:00 AM
actually i have planned every thing such as main hydraulic power pack and piston cylinder for expander up and down, tooling, tooling guide, frame . but there is some problem with chain sprocket mechanism. so please suggest me. i am too close to make this machine.
Good Answers: 102
04/10/2014 8:17 AM
I'm sorry vj, I have no idea how the sprocket fits into your mechanism. Is it for adjustment or power or what?
Photo time vj.
Good Answers: 150
04/10/2014 8:57 AM
would it not be easier to start with a tube and roll form/spin it? or stamp a whole bunch of what are essentially belleville washers and then laser or EB weld the seams?
Who is John Galt?
Good Answers: 102
04/10/2014 9:54 AM
Thanks for jumping in!
I was getting worried...
There are lots of extant fabricating techniquies and tooling. VJ seems hell bent on going the Heath Robinson route...
04/11/2014 12:44 AM
Good Answers: 102
04/11/2014 12:57 AM
Buy that one if it does what you want.
I don't see any screws, chains and sprockets.....
04/11/2014 1:07 AM
its is some modified machine, four leas screw posts are replaced by one column which is just behind the center pipe column in figure which makes up and down the circular platform, ok nothing matter i will do it after little practice,, i have already seen that machine and mechanism which i want, but missing image in my mind.
Register to Reply 15 comments
Rorschach (1); vijay bahadur (6); Wal (8)
