Previous in Forum: Programmable automation controller   Next in Forum: Wrong humidity readings!
Suggestions for a new Manometer
06/13/2007 10:41 AM
At the moment we are using the Dwyer Mark II tube manometer. I am wanting to change these and replace them with digital. This is for a paint booth. Any suggestions? These will be required to stay at (on) the paint booth so readings can be taken at will. Thank you, Bob
Pathfinder Tags: Manometer
Hobbies - HAM Radio - New Member Fans of Old Computers - Apple II - New Member Canada - Member - 'ssauga eh?
Re: manometer
06/13/2007 10:49 AM
There are a number of companies manufacturing solid state manometers for environmental monitoring purposes used in the pharma and electronics industries.
Dwyer is one of those manufacturers I beleive but check out global spec or use your favorite search engine. Some of these instruments are hidden in with the BMS systems they are associated with though.
If you do not require a solid state system but still want to get away from the problems of liquids then Magnahelic gauges are a a good inexpensive alternative that can give you continuous readings without the need of a power source.
there are 10 types of people on this earth. Those who understand Binary and those who do not.
Re: Suggestions for a new Manometer
06/13/2007 11:10 PM
Dwyer makes more than one digital meter that will work. Check your local
Grainger cat. I use two different meters almost daily one for up to 200"wc. and the other for less the 27"wc. both are great they are small with metal sealed cases. In your application I would mount them in your control panel and they last for ever (9 volt battery allowing).
Hope this helps
Mike
06/15/2007 12:30 AM
Try www.omega.com they have a variety of process instruments, and online ordering and shipping is a breeze!
Register to Reply 3 comments
Anonymous Poster (1); Solrac (1); thrudd (1)
