Previous in Forum: Turbine Gland Steam Mixes from End Sealing in Bearing Lubrication Oil   Next in Forum: Coil Spring Weight
15 comments
U Groove Weld Strength Calculation
04/10/2014 6:58 AM
what is the U groove weld strength calculation formula?
is there any difference in the weld strength of U groove and V groove?
thanks
Ask right person to get the right answer.
Good Answers: 34
Re: U groove weld strength calculation
04/10/2014 7:35 AM
Talaat, groove design is not a essential variable. is mainly governed by the thickness of the workpiece, the heat input and to saving consumable. Weld strength is the same.
WP
04/11/2014 6:49 AM
"groove design is not a essential variable"
API 1104
Good Answers: 34
04/11/2014 10:15 AM
Yes Dolby, you are right. I was talking about ASME XI. Also, we don't have the welding process, for some of them a change of the groove design is essential too.
Re: U Groove Weld Strength Calculation
04/10/2014 9:47 AM
There is no formula.
Why would you think this?
Your questions are nonsense.
Good Answers: 141
04/10/2014 10:09 AM
The idea is to fill up the groove with welding material. Once this is done properly, the strength:
1. Is that of the base material that contained the groove or,
2. Is that of the welding material you add or,
3. Is a strength between both 1. and 2.
It all depends on what materials you use and the way the weld has been performed.
Plenty of room here
Good Answers: 141
04/10/2014 10:10 AM
Plenty of room here
04/10/2014 10:31 AM
As others have commented, the idea for preparing a joint with a groove for welding is to ensure full penetration of the weld in the joint
Good Answers: 26
04/10/2014 11:13 AM
We used U preps on the PHM foils due to the greater strength of the weld when the foil was flexing. Still developed minor cracks.
04/10/2014 11:27 AM
I'm sorry, I've use acronyms too much......
U preps?
PHM?
Good Answers: 26
04/10/2014 12:18 PM
PHM= Patrol Hydrofoil Missle boat. It provided a stable platform to fire the gun and launch missles. It was a takeoff of the Jetfoil. I think they are all scrapped out now or being used as fishing boats.
http://en.wikipedia.org/wiki/Pegasus-class_hydrofoil
04/10/2014 12:36 PM
with the Acronyms,........ Reminds me of a scene in "Good Morning Vietnam"
with Robin Williams playing Adrian Cronaur saying "Excuse me sir. Seeing as how the VP is such a VIP, shouldn't we keep the PC on the QT, because if it leaks to the VC, you could end up an MIA, and then we'd all be put on KP."
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member
04/11/2014 2:52 AM
https://ceprofs.civil.tamu.edu/llowery/cven446/KeatingNotes/Keating%20Design%20of%20Welds%20Module.pdf
our people use it for fillet weld strength calculation,,, see if it can help.
otherwise just ignore
(engineering)...is the art of doing that well with one dollar that any bungler can do with two..
04/11/2014 2:57 AM
The strength shall not be influenced by the shape of groove as soon as the weld is properly done ( good penetration, no lack of fusion... ).
What is affected by the shape of the groove is the amount of weld deposit ( i.e time & money ).
04/11/2014 7:55 AM
In ASME, the weld deposit, I believe was called reinforce. And too much was frowned upon and can be rejected by our AI.
02/13/2015 10:18 AM
As far as I was knowing the weld deposit is all filler material added.
That's include what is inside the groove AND IN ADDITION the reinforcement.
The reinforcement is only the part of the weld that is above the level of base metal surface for butt weld and the one that is above the theoretical throath for fillet weld.
Of course that higher reinforcement than the specification may be rejected by inspector ( for usual applications and thicknesses, maximum accepted reinforcement height is 1.5mm to 3 mm - depending on the code used.)
However what is inside the groove is not reinforcement and this is the main amount of weld that is unnecessary added, if wider groove is used.
Register to Reply 15 comments
crstn (2); dolby (1); dvmdsc (2); lyn (1); ntr (1); phoenix911 (4); texasron (2); Whitephone (2)
