Previous in Forum: MIG Welding Question   Next in Forum: Pitch
Welding Thickness
04/15/2014 2:59 PM
How to calculate welding thickness requirement for pipes and plates?
Re: welding thickness
04/15/2014 3:30 PM
Should be the same thickness as the items being welded.
Are you and smathur72 and shebil all taking a welding class?
Download the American Welding Society documents.
FAQ: How do you determine the minimum size of a fillet weld?
04/15/2014 5:49 PM
The weld should be considerably thicker than a RCH. How much thicker the weld should be depends on what one is welding, the mechanical loads the weld will see, the phase of the moon, the welding technique and many other unspecified attributes.
04/15/2014 6:05 PM
I see you're from the old school.
Re: Welding Thickness
04/15/2014 11:32 PM
OTOH, if you are welding a pipe column to a base plate, non-moment connection, you might get away with less. It depends on such details.
04/16/2014 12:18 AM
1. What is your design code?
2. Is this for structural application?If so, what kind of load is acting on primary and secondary members (ie, static Load OR Dynamic Load OR Static and Dynamic Loading)?
3. Is this for pressure containing application?If so, what is the pressure and temperature of the service fluid?
4. Is this pipe to pipe weld OR plate to plate OR pipe to plate weld?
5. What is the material of construction? (Allowable stress value is determined based on base material such as ASTM,ASME,EN etc.)
Canada - Member - New Member
04/16/2014 8:14 AM
Yes indeed, more information of the application is required. I don't think that we are mind readers.
Never stop learning
04/16/2014 10:52 AM
To paraphrase Albert Einstein, make every weld as thick as possible but not thicker.
Register to Reply 7 comments
Anonymous Poster (1); Brave Sir Robin (1); Kevin LaPaire (1); lyn (2); redfred (1); Tornado (1)
