Previous in Forum: Change Of Name Plate In Revamping Area   Next in Forum: Welding Thickness
9 comments
MIG Welding Question
04/14/2014 7:20 AM
how can we calculate the weld thickness or depth required for a particular engineering steel of a required thickness. Like a pipe of 8000mm height 610mm in dia and 12.7mm thick being welded to a baseplate of 1176 dia and 60mm thick?
Re: MIG welding
04/14/2014 7:26 AM
Well, that would depend upon other loads upon the structure, which clearly is not behaving as a pipe any more. If it were just supporting itself on-end, for example, then it may sit there under its own weight and wouldn't need welding at all.
  • Suggestion 1: the undefined "we" hires a qualified Mechanical Engineer and that individual works from all the design information that is not listed in the original post; a set of first revision General Arrangement drawings for this watoosemedompfont, for example, would be a good first step.
Good Answers: 26
Re: MIG welding
04/14/2014 7:34 AM
The weld legs have to be a minimum of the wall thickness of the pipe.
Re: MIG Welding Question
04/14/2014 9:08 AM
It is not calculated, it is known by anyone knowledgeable in welding.
04/14/2014 9:57 AM
Which one is your joint configuration?
First
Second
Third
04/14/2014 10:02 AM
The one made with guano rods, obviously.
Good Answers: 18
04/14/2014 11:46 PM
What u are aiming is to weld a 12.7 mm thick to 60 mm thick plate.
It is a fillet weld joint and thumb rule is for fillet joint is:
The fillet leg size shall be 0.75 times thinnest of the 2 dissimilar thicknesses.
a. In your case it could be (12.70 (x) 0.75 = 10 mm) i.e., 10 mm leg length on
either side of the materials to be joined.
b. If designed purposefully for dissimilar thicknesses welding, then 0.75 % of
thickness on either side (12.7 (x) 0.75 vs 60 (x) 0.75 i.e.,Fillet leg size will be
10 x 45 mm.
c. But pl. check your design symbols (for equal & unequal leg lengths) and weld
accordingly.
d. Use AWS SFA 5.1 E 7018 type electrodes (4.0 mm size) for the welding.
sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Good Answers: 18
04/14/2014 11:50 PM
One correction pl.
Since you are using MIG process, use 1.2 mm size filler wire with recommended amps / voltage setting as per manufacturer's recommendation.
sorry for the lapse.
sridhar.
Canada - Member - New Member
04/15/2014 9:04 AM
General rule of thumb (unless you are a qualified welding engineer and can calculate the joint configuration) is 1000 lbs per inch of weld per 1/16" of fillet is the weld strength using an ER480S6 wire with appropriate shielding gas. You will need to check the loads being applied and may have to prep the joint for enough weld strength as just increasing fillet size isn't always the answer. Fillet sizes rarely exceed the thickness of the thinnest material.
Never stop learning
Good Answers: 26
04/15/2014 10:16 AM
Look, if this baseplate is on the ground and the pipe has ANY structural load that is dynamicaly loaded then you need gusset plates to support the pipe.
Save yourself a court date and get a structural engineer to calculate the design.
Register to Reply 9 comments
Anonymous Poster (1); dolby (1); Kevin LaPaire (1); lyn (1); PWSlack (1); SRIDHAR (2); texasron (2)
