Previous in Forum: Steel Reinforced Extrusion   Next in Forum: Gussets In Stayed Surface As Per ASMESec I
Girth Gear Joining Bolts
04/21/2014 11:35 AM
kindly provide kiln girth gear joining bolts material composition & specifications,
particularly used in cement plant manufaturing.
Re: Girth Gear Joining Bolts
04/21/2014 3:08 PM
Kindly read the as-built general arrangement drawings in the kindly operation and maintenance manual kindly supplied with the kindly equipment supplier when it was kindly built. Either that or kindly pick up the telephone and kindly ring them and kindly ask.
Good moaning!
04/22/2014 12:27 AM
Get the make, model and serial number of your machine and ask the manufacturer for a parts list.
04/22/2014 11:27 PM
There is no good reason to expect any particular standard for this. You can use lots of cheap bolts, or a few high-quality bolts.
Good Answers: 181
05/02/2014 8:33 PM
Contact FLSmidth or ThyssenKrupp Polysius
Register to Reply 4 comments
Crabtree (1); lyn (1); TonyS (1); Tornado (1)
