Previous in Forum: Indian Code For LPG Piping Inspection   Next in Forum: Failure Rate Of Belt And Rollers Of Supermarket Checkout
About Bolt Pretension and Moment
04/22/2014 2:03 AM
Dear Sirs:
I want to know the relationship between bolt pretension and moment of M20, who can give me some hints? I am very grateful for your kind help!
weijunmei
Good Answers: 137
Re: About bolt pretension and moment
04/22/2014 6:40 AM
The usual formula is
Tightening torque (N.m) = 0.2*bolt pretension (N)*nominal bolt dia (mm)/1000.
This is on basis that thread pitch = 1/8 bolt dia, and only 10% of the applied torque results in bolt tension (the rest is lost in friction), as you can check for yourself.
Good Answers: 150
04/23/2014 7:38 AM
codemaster, that 10% number is WIDELY variable. so much so as to make the calculation useless for almost all situations. the ONLY true reliable way to obtain pretension is elongation of the bolt. thread lubrication state as well as machining finish and tolerances make using torque as a stand in for pretension worse than useless.
Who is John Galt?
Good Answers: 137
04/23/2014 8:47 AM
Useless or not, I wouldn't mind betting that 95% of what must be millions of bolts tightened every day worldwide are done either to a torque figure or no measurement at all, just what feels right to the fitter. I've tightened plenty in my time, very few of them with a torque wrench, even less with any tension measurement, direct or indirect, and I haven't had noticeable problems.
I was trying to answer OP's question. The formula I quoted is given in suppliers' literature (with comments about lubrication, hard washers etc, which maybe I should have mentioned). In most cases it's not that critical. As you know, this subject has been discussed at length on CR4, and OP could do a search to get more background.
Good Answers: 58
Re: About Bolt Pretension and Moment
04/23/2014 9:43 AM
Hint #1, What the previous responders have advised.
Hint #2, Accurate measurement of bolt length.
Hint #3, Use a strain gauged bolt that measures elongation.
Good Answers: 137
04/23/2014 10:37 AM
I said in #3 that this has been discussed before, but I'd forgotten just how much! If you type bolt torque into the search box you'll find enough to keep you busy for a while.
Good Answers: 137
04/23/2014 10:39 AM
Register to Reply 6 comments
Codemaster (4); Rorschach (1); welderman (1)
