Previous in Forum: Stages in the Pump   Next in Forum: Motor Automatically Started While Putting Test To Service Position
15 comments
Suggestion for a Project
05/04/2014 3:17 AM
Hi i am naveen well in these days we can find many electrical engineers achievements where there are many mini and main project in those basic small example : on and off of motor in agricultural field by using gsm technology are these Technics are really applied in real life for name sake have we implemented it. only in few places it have been implemented.where as many such applications are there which are not implemented if we implement somewhat we could help our society.and we can get gain knowledge in core part. b-tech graduates are doing this project for name sake (not all, only few are doing heart fully) i don't want all those big projects if at-least we can implement this then we can go to higher project. i am going to try one of those mini basic example of agricultural field in remote area i mean in less developed area. i want to built a device with following specification:Agricultural Bases:1: showing current status2: which phase current is there3: condition of motor4: on and off of motor5: minimum usage of current6: status of motorin India there are still few places where farmers have to travel 5 to 6 km to their field.we have to overcome this difficulty.now main question are:1: weather this project can be done successfully or not 2: will anyone support this3: what are the dis advantage and advantages in this4: is there anything else that we can implement in this5: i am working on this i need some more to help me on hardware purpose (its totally voluntary work just for knowledge)don't mind it might be silly but i should have a clarity and i need help i thought it might help me
Re: suggestion for a fresher for a project
05/04/2014 10:43 AM
05/04/2014 12:30 PM
thanku sir.. i tried to edit it but its not coming.. thanks for the suggesion..thanks a lot
Good Answers: 67
05/04/2014 1:54 PM
GA for coming back and saying "Thank you."
Not many who come here with a question do that.
05/05/2014 2:12 AM
Look at the microcontrollers and sensors at sparkfun.com, they have a cellphone adapter for about $50 US...they also have Zigbee standard transmitter-receiver link pieces you would need. What you described to do parts cost appx. $350-400 USD and software time, lots of examples of use of same at Auduino website.
05/05/2014 2:18 AM
thanks you sir
05/05/2014 10:16 AM
I have been using microcontrollers and Zigbee networking parts to link them together and thought it might have been a mistake as the GSM units seemed more economical...the controller might be, but then each device requires a cell phone, and that would require me to spend an additional $15 per month per unit, which makes GSM more expensive as my links are all less than 2km.
Good Answers: 19
Re: Suggestion for a Project
05/04/2014 11:33 PM
This is possible. Cost will be prohibitive for any Farmer. There are remote monitored Energy meters available with data acquisition. These meters are to be located to in the motor circuits. These meters will capture all the data like current,voltage ,power and energy etc., after capturing these meters will transmit data .The data has to be linked to particular channel/server, from the server the data can be seen by the Farmer remotely in smart mobile phones.
Ramesh,Freelance Electrical/automation Consultant
05/05/2014 2:21 AM
thank you sir.thanks for the suggesion
Good Answers: 25
05/05/2014 6:38 AM
Naveen, Good to hear that you are trying to help Indian or any other farmers. I understand their problem as they have to get up in middle of the night and switch on their pumps in case of lift irrigation schemes. This problem is not faced by farmers having tube well irrigation. I had heard in past some one in India had developed circuit with help of two mobile phones for switching on the pump. As per circuit one mobile is installed in farmer's home and other in the field near pump. Pump switch is controlled through mobile. You can think of similar circuit.
05/05/2014 7:15 AM
the method which you said was developed by a person from gujarat. he just started basic version just to on and off of motor. i have gone through it.
well however thanks for the support . thanks a lot sir
Good Answers: 19
05/05/2014 7:54 AM
In this method, you can have mini PLC located near the motor, which can receive SMS to switch on or switch off the motor. This PLC will have modem module to receive the SMS and act. This becomes slave station. Where as the requirement is to transmit the data then it should be Master.
Good Answers: 102
05/05/2014 8:28 AM
You want to remotely control and monitor irrigation pumps in rural India?
My gut feeling is that this is futile but I might be wrong....
First step would be to determine and document exactly how the farmers are operating their remote plant now, what their security concerns are, how reliably this remote plant operates, what the costs are associated with their operations and so on...
then......
Try to improve on that.
I'd be betting that most pumps in rural India are diesel driven, relocated very frequently then brought home and locked up every evening.
05/05/2014 9:45 AM
yes sir i have gone through 6 villages in prakasham district in ap they have such kind of problem of on and off and motor failure etc problem after seeing these things i got this idea. according to my sense its not going to be futile...still there are many places they don't have proper motor and you are saying remote motor.they don't have awarness of such techniques.as a citizen can't i develop them by my small idea ?
it might look silly but we can't neglect right :).
thanks for the rply....
Good Answers: 117
05/06/2014 10:36 AM
Does not seem silly to me.
However, without walking through rural India with YOU, I have no idea how to fix whatever problem there might be. I usually find that the problem is obvious when I see it...and it might not be the problem I thought it might be. For instance, I never thought of bringing pumps home like Wal suggested.
05/20/2014 1:25 AM
You can make an auto live phase selector using two contactors. The 24 hour timer that is easily available (or you can design one) can be used to switch on the pump(s) at predetermined time and duration.
Gajanan Phadte
Register to Reply 15 comments
dnaveenkumar (5); europium mkII (1); geraldpaxton (2); gmphadte (1); lyn (1); ramvinod (2); suresh sharma (1); Wal (1); Yusef1 (1)
