Previous in Forum: RS232 Data Transmission Problem   Next in Forum: Question About Transmitter Connection
Dual Solenoid Valve for Reliability?
05/06/2014 6:56 AM
What is the best pneumatic configuration for two pilot operated 3/2 way solenoid valve to be used for on-off of a ball type quarter turn shutdown valve.
There are two outputs from the same logic carrying same valve driving each of the solenoid valve.
Re: Dual Solenoid Valve for Reliability?
05/06/2014 6:25 PM
Explain what you want to a valve company.Go here and search: Search GlobalSpec
Or ask one of these:
ASCO Valve | ASCO RedHat Solenoid Valves | World's Leading ...
STC Solenoid Valves - StcValve.com
Be ready to explain in clearer terms than these.
Good Answers: 203
05/06/2014 10:44 PM
Contact Parker (Parker-Hannifin) http://www.parker.com/portal/site/PARKER/menuitem.223a4a3cce02eb6315731910237ad1ca/?vgnextoid=c00aeea74775e210VgnVCM10000048021dacRCRD&vgnextfmt=default&vgnextfmt=EN
They have a very extensive line of pneumatic valves, fittings and other devices. I have had extreme success in years past. They, at one time, also had the best set of training books in the pneumatics fields. Now they have on-line training.
Many people, including myself, used to make process control pneumatic computers for chemical processing before the IBM and Apple became popular. They were great for explosion proof areas. They could do most things that a PC could and many things they couldn't do. One of the best things about them is that pneumatics can do many things that electrical units require interfaces for.
Good Luck, Old Salt
05/06/2014 11:05 PM
Hi, I'm not sure if this will help.
In my experience a 3/2 solenoid takes a single pneumatic input, and has 2 pneumatic outputs. It takes a single digital on/off signal.
When the solenoid is signaled to open it will direct air supply to one of the outputs (which can be used to move a single acting actuator on a valve). When the solenoid signal is removed, the solenoid internal spring forces the input closed, and the previously pressurised output is vented through the second output.
When pressure is removed from single acting actuator, the actuator spring pack moves the valve to its fail position. In case of either power failure or air failure, a single acting actuator will cause valve to fail to the set position based on spring pack within the actuator.
If you have double acting actuator (i.e. requires air to open & air to close), then you either need 2 x 3/2 solenoids or 1 x 5/2 solenoid.
A 5/2 solenoid will direct a single pneumatic input to one of two pneumatic outputs (one is directed to each side of the actuator, so when the solenoid is switched using a single digital signal, it will either open or close depending on how it is configured).
A double acting actuator (on electrical fault) will fail to the spring position in the solenoid. But on air failure will fail to last position.
Hope this helps.
Anthony
05/06/2014 11:08 PM
All the more reason for the OP to seek professional help instead of asking strangers on an anonymous forum for help to do his job.
05/07/2014 5:54 AM
<...There are two outputs from the same logic carrying same valve driving each of the solenoid valve....>
Therein lies the rub. Are those outputs logical OR with a spring return, logical AND with a spring return, or air-each-way? Valve suppliers' sales offices need to know...
ajwinemaker (1); lyn (2); old salt (1); PWSlack (1)
