Previous in Forum: FP400 Cables   Next in Forum: Why Does The Servo Motor Quotes With Newton Meter Instead Of Kilowatt?
Motor Solo Run Test Duration
05/07/2014 8:18 PM
Can anybody please tell me which IEC / IEEE / NEMA / BS / any other standard specifies the duration for motor solo run test?
I am looking for 0.37kw to 250kW 400V / 690V motors.
Re: Motor Solo Run Test duration
05/07/2014 8:35 PM
Where are you located?
Could be NEMA DIN or JIS.
Re: Motor Solo Run Test Duration
05/07/2014 10:26 PM
I have never heard of such a test. What is its supposed purpose?
05/07/2014 11:31 PM
Baba Ji knows..................................................
Good Answers: 445
05/08/2014 12:12 AM
Call it an uncoupled test, the motor by itself (solo) with nothing on the output shaft(s).
05/08/2014 12:23 AM
Easily understood in advance, but how much purpose? Of course, one can test controls, notably oil failure switches, but would there be a meaningful duration requirement?
05/09/2014 3:48 AM
When we install new motor-pump assembly, before we hand-over motor to mechanical guys for coupling to the pump, we do solo run test. We monitor motor temperature, bearing temperature, vibrations etc. Check for any leakage / noise / confirm D.O.R. This confirms that motor is alright before coupling to mechanical side.
This duration normally shall be long enough such that no further increase in bearing temperature observed. Normally 2hrs. to 4hrs.
But I don't know which standard specifies duration in hours.
If anyone knows please share.
01/10/2016 9:28 AM
I performed SOLO Run Test many times. It was a 4 hour run test as per menufecturer instructions, however for a wide range of motors I used 4 hour test.
and for those who dont know about solo run test, it is a condition when motor is subjected to run without any load, even connecting to its own rotor.
Register to Reply 7 comments
arshadtanoli (1); lyn (2); nshingate (1); RAMConsult (1); Tornado (2)
