Previous in Forum: Lightening Arrestor and Earthing   Next in Forum: Measuring short duration noises
Vacuum Sealing
06/19/2007 9:24 AM
I am looking for a technique to seal a glassy bonded package, for a vacuum device application.
can you help me? or tell where can I search the case?
Thanks.
Re: Vacuum Sealing
06/19/2007 10:50 AM
You might ask this question in the manufacturing or general section.
Good Answers: 109
Re: Vacuum Sealing
06/20/2007 2:10 AM
Hi,
if you want high vaccum only it is possible to make a good seal by epoxi (very thin very flat no trapped gas bubbles high temperature curing), we use these down to 10exp-7mbar without problems.
If temperature at use is high or pressure is lower than you can try either anodic bonding or metalising of the glass and then brazing or take a glass type that can be directly sealed to metal as in the lighting bulbs.
RHABE
Good Answers: 94
Re: Vacuum Sealing
06/20/2007 5:53 AM
Do you have more details of the package? There are several methods of sealing but the choice would depend on the size, shape & material of your package.
Re: Vacuum Sealing
06/20/2007 7:25 AM
You can contact Hermetric, Inc. http://mysite.verizon.net/tom.es/. They will be happy to forward an application note on vacuum sealing using projection welding technology.
Good Answers: 40
Re: Vacuum Sealing
06/22/2007 10:23 AM
As noted by others, more specifics about the item in question are required.
You might benefit from vacuum sealing using polyester / vinyl-ester or epoxy resins. A great resource is fiberglast.com (see vacuum products at: http://www.fibreglast.com/showproducts-category-Vacuum%20Pumps-172.html where every imaginable cloth/weave/mat/flake and powder filler are also available, as well as a wealth of educational materials.
Good Luck!
Anonymous Poster (1); bhankiii (1); ndt-tom (1); Nigh (1); RHABE (1)
