Previous in Forum: Condensation in Gas Detectors(Hazardous Area)   Next in Forum: Why the Official Explanation of MH370’s Demise Doesn’t Hold Up
Hobby Rock Tumbling
05/15/2014 10:38 PM
I have been rock tumbling for a while on and off as a hobby. Been rock hunting every time I get near a creek, stream, lake or other areas near water. Was wondering if anyone has done the same. I have a hard time finding the right tumbling grits in large amounts. Only find packages in small quantities at some tool supply places. Would like to know where is a good place to check out? Thank You
Good Answers: 444
Re: Hobby Rock Tumbling
05/15/2014 11:53 PM
What quantities and prices are you looking for? While hobbyist places charge $6/lb and more, you can find various types and grades of sandblasting grit in industrial quantities (25 lbs or more) for $0.80 to 1.00/lb here. I'm not sure if I would use it for finish work, but as a first and second cut why not.
05/16/2014 2:40 AM
No links to hand, but CR4 has some good stuff on this. It's a little bit 'hillbilly engineering' (oil drums and home build stuff), but possibly mentions materials.
If you can do so, then buy in bulk to minimize cost. It's no quick job if you want to get it right. As far as I know, the real art is in the final stages. Links have already been given, but it's worth searching around CR4. For one, I'd be much interested to hear how you get on.
Good Answers: 266
05/16/2014 7:38 AM
05/16/2014 7:44 AM
The same grits used for grinding and polishing telescope mirrors are used for rock grinding and polishing. Newport Glass carries a range of carbide grits.
From their main page:
http://www.newportglass.com/index.htm
click the link to get to the online astronomy catalog.
http://www.newportglass.com/angwcat.htm
In the left column you can scroll down to get to the link for carbide grits.
Good Answers: 145
05/16/2014 7:55 AM
I think I pay about $10 for a 40 or 50 pound bag of sandblasting grit at Tractor Supply. It is available in at least two, possibly 3 or 4 different grits. I'm sure it is not as good as optical grade carbide grit but I'm also sure it will grind down rough edges during the first few tumbles. The final "gloss finish" tumble may or may not need better grade grit.
Good Answers: 59
05/16/2014 5:26 PM
Here are some previous posts about rock tumblers. The one called "DIY Rock Tumbler" in the Workbench Creations blog is good. http://cr4.globalspec.com/search/sitesearch?do=show&srchobjs=t%2Cbe&order=asc&sort=textmatchrank&srch=rock%20tumbler
05/17/2014 12:05 PM
Nice one !
Register to Reply 7 comments
BruceFlorida (1); Kris (2); ozzb (1); RAMConsult (1); SavvyExacta (1); Usbport (1)
