Previous in Forum: Turbine Governor   Next in Forum: *** CFD - Fluid Mechanics BLOG ***
Air Compressor : Screw Compressor or Integrally Geared Compressor
05/21/2014 8:12 AM
I want to choose an Air Compressor of following specification.
Inlet Pressure : ATM
Discharge Pressure : 109PSIG
Flow : 1942SCFM
Inlet Temperature Max. : 48 Deg C
No oil free air is required ( Oil carryover not a problem).
Which one will be the right compressor for above application?
1. Screw Compressor
2. Integrally geared Centrifugal compressor
also please give cost comparison of above two.
Regards,
RAtheesh
Re: Air Compressor : Screw Compressor or Integrally Geared Compressor
05/21/2014 9:34 AM
Ask here: Search GlobalSpec They have many there.
05/21/2014 9:52 AM
Have you considered a Rotary Vane compressor?
I have no experience with integrally geared centrifugal compressors but I have found screw compressors can be problematic (I suppose this statement will divide opinion).
I will be surprised if anyone recommends either of the two compressors you have suggested based on the information you have given.
What type of plant is receiving the air? What environment will the compressors be operating in? Has the piping distribution been sized correctly? You mentioned that oil free air is not required but how about moisture?
The design of a compressed air system does require a lot of thought regarding numerous considerations. Your stated volume flow rate points to a reasonable capital outlay. Proceed carefully.
Good Answers: 266
05/21/2014 10:10 AM
Neither or both because they are specs not an application. Both can provide the specifications.
05/21/2014 11:19 AM
How many compressor suppliers are you talking to, Mildred?
Good moaning!
05/21/2014 12:19 PM
Judging from OP's past history, I say zero.
05/22/2014 1:29 AM
Hi,
installed a screw compressor last year.
It cost 4 x what a piston type cost for just a little more in terms of volume (Which we do NOT need).
The advantages are:
Much less noise in the work environment
Aesthetically more pleasing
Less Maintenance and easier to keep clean.
05/22/2014 6:33 AM
Ask any manufacturer if their compressor ....will be the right compressor for above application?... and if the so no ...then go to another one.
Register to Reply 7 comments
Adnaan146 (1); Crabtree (1); horace40 (1); lyn (2); NR-28 (1); ozzb (1)
