Previous in Forum: Specific Heat of wax   Next in Forum: Calculating Fluid Flow for Hydraulic Motors
Dish End of Pressure Vessel
06/21/2007 10:09 AM
Friends I want to calculate the blank size of Dish End of pressure vessel.
Is there any standered formula for this.
Pathfinder Tags: Dish End of Pressure Vessel
Re: Dish End of Pressure Vessel
06/22/2007 2:48 AM
You can add up the blank radius by scaling from the drawing on the outside.+5%.
Holds for Spinning/Hot pressing/Explosives forming
06/22/2007 9:28 AM
A good reference is PRESSURE VESSEL HANDBOOK, by Eugene F. Megyesy, published by Pressure Vessel Publishing, Inc. P.O. Box 35365 Tulsa, Oklahoma 74153 USA.
Curtis F. Metz, III PE
06/27/2007 11:02 AM
For elliptical heads, the approximate blank dia. d shall be:
d = 1.2 (Do - t) + 1.5 SF + 30 mm [from catalogue of J Bown & Co., England, www.jbown.com]
where,
d = Approximate blank diam., mm
Do = Head outside dia., mm
t = Plate thickness (or min.), mm
SF = Straight flange height, mm
08/19/2009 1:47 PM
Abdel - you seem to have good information here. Is there a guidance for sizing reinforcing pads for nozzles on dished ends of pressure vessels? I have a vendor who is providing a 24" reinforced nozzle on a 72" diameter dish, the client wants me to check their submittal.
Thanks in advacne for any feedback.
Register to Reply 4 comments
Abdel Halim Galala (1); metzc3 (1); MUKULMAHANT (1); thinman56 (1)
