I want to replace some water wall tubes which
are connecting top and bottom header of a boiler. Bottom header to tube joint
has space limitation. Ie, back side of the joint has limited access .I think,
welder need help of a small piece of mirror to get back side view of the joint during
actual welding. So, it is very difficult for a welder to use normal GTAW aka
TIG torch with long back cap to weld that joint. From where I can get GTAW torch with smallest back cap?
