Previous in Forum: Need Clarification on Tuned DP Transmitters   Next in Forum: Honeywell Server and Station Timing Synchronization Issue
Type of Actuator
05/25/2014 12:48 PM
Dear All
For Expanding DBB plug valve
https://www.youtube.com/watch?v=yOlgtT9_sBg
what kind of actuator is suitable (multi turn or part turn )
regards
jose
Re: type of actuator
05/25/2014 12:53 PM
Did you watch the video?
Re: Type of Actuator
05/25/2014 3:09 PM
It was so entrancing that he couldn't count past one?
05/26/2014 12:30 AM
As Lyn and Tornado indicated, if you watch the video, it is quite clear that the handle turns several revolutions to open or close. The standard actuator is a pair of hands!
If you want it to be remotely or automatically controlled, it will require some device that will turn the correct number of revolutions and then stop when fully open. Of course it must reverse the motion to close the valve.
One obvious possibility would be a gearmotor with limit switches at each end of the motion.
Another possibility would be an air- or hydraulically-actuated piston pushing and pulling a rack that engages a pinion mounted on the valve shaft.
There also exist rotary air motors...
05/26/2014 1:32 AM
Without wishing to state the obvious, the video is pretty conclusive that a multi-turn actuator is required.
Good Answers: 21
05/26/2014 9:01 AM
Josej,
The video clearly demonstrates a multi-turn operation, and I would guess that in a DBB configuration, tight shut-off is paramount, and you probably get better and more repeatable results from such a gradual toque application.
dkwarner (1); DMC123 (1); Hilton (1); lyn (1); Tornado (1)
