Previous in Forum: Can a Peltier Element Cause a Fire?   Next in Forum: Aluminum Pressure Relief Flaps for Arc Fault Test
How Can I Bench Test a Two Level Control Relay Crouzet HNM 84 840 700
05/25/2014 8:05 PM
HI
I work in Australia
I am trying to bench test a two level control relay. I wire the relay as per the supplier diagram and set as required for the two levels control. None of the led will come on or flash. But if I test A1 and A2, with a voltmeter I can see that the relay is energised, What am I doing wrong? Can those relays be bench tested ?
Re: How Can I bench test a two level control relay Crouzet HNM 84 840 700
05/25/2014 9:11 PM
I haven't worked with this particular Crouzet relay but chances are you haven't connected it up correctly.
Check their website for a detailed manual or application note if you haven't got one, they generally are detailed and easy to understand.
05/26/2014 4:37 AM
Thanks for your answer I found out what my problem was. The maintenance manager was trying to replace a faulty relay with another faulty one . I have ordered new ones . Never had lights on or contact between 11 and 12 . At least now I know perfectly how they work. Thanks again for your answer.
05/25/2014 10:25 PM
How are you simulating the presence of liquid at each of the two levels?
Location: KCM, chingola; copperbelt; zambia; southern africa.
Re: How Can I Bench Test a Two Level Control Relay Crouzet HNM 84 840 700
05/28/2014 3:22 AM
show me the circuit and i will tell you how it should work.
an error does'nt become a mistake if corrected!
Register to Reply 4 comments
DmanEng (1); jack of all trades (1); prems974 (1); Tornado (1)
