Previous in Forum: How Can I Bench Test a Two Level Control Relay Crouzet HNM 84 840 700   Next in Forum: SCR Electrical Power Controller
11 comments
Aluminum Pressure Relief Flaps for Arc Fault Test
05/26/2014 5:26 AM
For pressure release is it a good solution to give pressure flap in aluminium in order to enable faster opening....or is it a common industry practice?
Re: Aluminium pressure relief flaps for arc fault test
05/26/2014 9:43 AM
CR4 ADMIN: Deleted Post
Abuse/Attack: This post was deleted because it was an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
05/26/2014 1:23 PM
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
05/26/2014 3:31 PM
05/26/2014 3:39 PM
05/26/2014 5:10 PM
05/27/2014 6:06 AM
Re: Aluminium Pressure Relief Flaps for Arc Fault Test
05/26/2014 3:45 PM
What standard are you working to?
My exposure to switchboard arc fault design is limited but the pressures involved are enormous, I cannot see how a slightly lighter pressure release flap would make any difference at all!
I have seen switchboards explode under controlled outdoor laboratory tests like they were hit with a howitzer!!! Orange vaporised copper smoke and all.
Why aluminium (is this your idea)?
05/26/2014 11:57 PM
I just felt that a few milliseconds of earlier opening of flaps could help in reducing the pressure on my structural parts. Just an idea i wanted to discuss. I saw one of the manufacturer showing aluminium flaps for quick opening.
05/27/2014 12:13 AM
05/27/2014 12:32 AM
Someone once tried to convince me that the reason thugs in the movies pushed the hand gun forward before they pulled the trigger was that it increased the speed of the bullet. This sounds a bit like that to me.
The stress to the (properly vented) enclosure is far less of a concern than the stress to the bus bars and supports due to the current.
Good Answers: 122
05/27/2014 10:23 AM
It might work however I am not sure the cost would be justified by any real improvement in perfromance.
Aren't you concerned that it will create a much weaker structural barrier (weak point) which most likely will partially or completly vaporize the first time an arc flash of any magnitude occurs?
Register to Reply 11 comments
electric_baba (2); geraldpaxton (1); jack of all trades (3); lyn (3); PWSlack (1); SHOCKHISCAN (1)
